Results 1 to 14 of 14
Thread: Vs V6 Berlina suspension help
    vs
    Mar 2011
    australia
    Default Vs V6 Berlina suspension help
    Hey guys i got a vs v6 berlina with 18 inch rims.
    ultra low king springs
    but for some odd reason the rear right side is 2 finger gap while the other side left is 1 finger gap
    My car is sitting on King springs, app its the shocks that isnt it letting it sit low as it should be? because its still not as low as i want it
    any other reasons it might be?
    any help will be great thanks!
    vs
    Mar 2011
    australia
    1997 VS COMMODORE,1996 GTS-R COMMODORE
    Feb 2011
    NEWCASTLE
    vs
    Mar 2011
    australia
    Quote Originally Posted by EDGE3 View Post
    Have you got the camber done on it
    Nup, all i have done to it is put ultra low king sprngs.. and tomarrow getting the shocks
    Feb 2011
    NEWCASTLE
    You should also get a camber kit done on the rear,I have the same car as you and the same suspension done I also had a castor camber kit put on the front.My rear springs are lowered heavy duty ones which is great if you tow anything,you also need to put in a smaller panhard rod because you have put in lowered springs
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    Does it have IRS or live axle ?
    If you want to check if the shocks are causing the problem just take them out ( just the back ones ) and see if the height levels out. If its still uneven with them out then its not related to the shocks.
    Feb 2011
    NEWCASTLE
    vs
    Mar 2011
    australia
    Na my commodore is live axle
    so i dont think its the camder? or still possible?
    Feb 2011
    NEWCASTLE
    VS Berlina
    Apr 2011
    NZ
    Its the panhard rod youll need to chuck an adjustable one in there especially if you wanna go lower. if you see live axle commys that havnt had one and when you sit behind them they actually crab slightly sideways down the road lol
    VS Executive S2
    Aug 2010
    melb
    94 VR Executive & 99 VT XU8
    Mar 2005
    Melb
    i did not know 'any' vs's did not have IRS.
    94 VR V6 - No ABS & NO IRS... a true mans steed and a 99 VT XU8 for good measure.
    VS Berlina soon to be 5L
    Aug 2010
    Girrawheen
    hsv91ss's Avatar
    hsv91ss is offline Holden4eva!
    VS Commodore SII
    Jun 2005
    Central Coast
    I have never seen a Lowered commodore crap sidewayz, but I before I used an adjustable Panhard rod on almost every bump the tires rubbed and made a hell of an awful noise.
  1. Suspension - VT Berlina
    By stevebutler in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-12-2010, 09:42 PM
  2. [NSW] vn s2 v6 berlina sunroof 9 months rego new 18s new suspension
    By wineo123 in forum Vehicles For Sale
    Last Post: 31-07-2010, 02:21 PM
  3. VT2 Berlina front suspension rattle noise
    By VTowner025 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-05-2010, 12:37 PM
  4. VS Berlina 6Pak with brake/suspension issues
    By Possesed 95 VS Berlina in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-07-2009, 08:51 PM
  5. Replies: 57
    Last Post: 12-10-2006, 08:47 AM
