Results 1 to 7 of 7
Thread: Tacho has got Tourettes
    96 S II VS Clubby, 96 VS S II Executive
    Jul 2010
    perth wa
    Default Tacho has got Tourettes
    hi fellas its been a while i've had this issue but its stupid now. My tacho basically is spastic all the time, it just flys and jumps up nd down the dial. doesnt even hang around the aproximate rpm, i've seen it at moments hangin around 3000rpm on idle, WTF? Any ideas to fix this???? tis really giving me the shits now. thanks
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    YouTube - VN no limits
    Ohh yeah i seen that before
    Reaper
    Jul 2010
    perth wa
    haha wtf. yeh am thinking i have to rip bloody dash out nd git it a spray with contact cleaner, but i have no idea what caueses it?...
    VR wagon, 5 ltr ski boat,
    Sep 2009
    Broome
    Good chance the wiring membrane is starting to crack up and makes intermitant conection.. Usualy breaks at the plug where the membrane is bent over..Temp and fuel are usualy the 1st ones to play up/
    If your good with a soldering iron you cam repair the tracks.
    VS UTE, HT MONARO REBUILD
    Dec 2010
    Hey mate my VS ute has the same problem only it wasn't just the tacho my whole engine was spastic, i changed the plugs and leads as i had a miss fire which i thought was linked to it, the new gear helped make it run a bit smoother and it now rarely chucks a spaz but still has a missfire, so im thinking Coilpacks, as one has a different volt reading to the rest or even a DFI module. hopefully this helps but if it's just your Tacho then more then likely its a wiring problem.
    Jul 2010
    perth wa
    yeh i reckon wiring too. But to your crazy uterus i reckon is DFI or ignition module, i just had an issue with the clubby yesterday and after much research those characteristics are symtoms of a "on its way out ignition module"... wish mine had symtoms
    Stuntmanmike: At least he didn't advise for me to check the head light fluid and bring it in to tune the radio...
    vs caprice
    Dec 2010
    brisbane
    i had prob with me tacho doing the same as urs m8 was doing it for about a month then the module died then the tacho was fine after i replaced the module
  1. tacho pin
    By lion_g in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-04-2010, 11:58 PM
  2. hsv tacho into berlina 5.7L standard tacho
    By genaero20 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-09-2009, 04:08 PM
  3. VN Tacho-Less Dash To Tacho
    By Evman in forum General Discussion
    Last Post: 01-03-2008, 08:32 PM
  4. Dash with tacho fit into dash w/out tacho and work????
    By Jamie_87 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-11-2007, 09:21 PM
  5. Tacho out?
    By G4orce in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-01-2006, 05:19 PM
