Results 1 to 4 of 4
Thread: VS air bag light is back
    VE Berlina
    Feb 2010
    Melbourne, VIC
    Default VS air bag light is back
    I recently put my car through a roadworthy, the air bag light was showing so my mechanic completely tested and reset the computer, everything was fine and it didn't show any problems.
    Yesterday I noticed it has come back on, something must be setting it off but what?
    vs commodore
    Oct 2009
    Tamworth NSW
    It could be the clock spring behind the steering wheel,if the steering wheel has been removed at some time,the clock spring can cause problems if it has not been re centered properly before the wheel is put back on.Id also check the SRS module wiring connectors,the SRS module is a box thats screwed to the floor under the drivers seat,also check the SRS wiring running through the dash/steering column area.The SRS wiring around the dash area is yellow with security pins holding the connectors together..Id just go through all the connections to make sure none of the contact pins are corroded or bent or whatever....
    If you can get someone with a scantool to check the DTC codes for the SRS system,it should give you an idea as to where the problem roughly is.....Heres a list of the VS SRS DTC codes...Remember that these codes can only be read and cleared with a scantool.Usually a Tech 1 scantool at a holden dealers...
    DTC CODE DESCRIPTION
    13 Driver's Airbag Circuit Short to Earth
    15 Driver's Airbag Circuit Short to Battery
    23 Passenger's Airbag Circuit Short to Earth
    25 Passenger's Airbag Circuit Short to Battery
    31 Driver's Airbag Loop Resistance High
    32 Driver's Airbag Loop Resistance Low
    33 Passenger's Airbag Loop Resistance High
    34 Passenger's Airbag Loop Resistance Low
    43 SRS Warning Lamp Short to Battery
    44 SRS Warning Lamp Circuit Fault
    48 Ignition Input Voltage Low
    49 Ignition Input Voltage High
    53 Configuration Mis-Match
    55 Sensing Diagnostic Module Fault
    66 Airbag Deployment Commanded
    VE Berlina
    Feb 2010
    Melbourne, VIC
    Quote Originally Posted by Brett_jjj View Post
    I will check those, my mechanic said he already tested the computer for errors and nothing came up, then he reset it to get rid of the error light.
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by Pickled View Post
    If the SRS dashlight is on,then there will definitely be an SRS error code logged.If theres not,and the light still comes on,then Id say that the SRS module is probably cactus...ask your mechanic if his scantool can actually read the SRS codes,or does it just clear logged SRS error codes?You really need to find out what the logged error code is, to get an idea of where in the SRS system the problem lies....
  1. Auto Back Light
    By benno9911 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 01-10-2010, 08:42 AM
  2. climate control back light in a VS
    By kill_switch in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-07-2009, 12:00 AM
  3. Air Bag Warning Light.... It Came Back !!!!
    By evil_monkey in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-06-2009, 11:58 PM
  4. red light in back door
    By goodyear in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-12-2006, 01:45 PM
  5. how do i fix break light on back of ss ute roof?
    By djvsa in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-11-2006, 11:31 PM
