Results 1 to 9 of 9
Thread: VX SS rims on VR Wagon?
    VK EXEC EFI
    Jul 2006
    Default VX SS rims on VR Wagon?
    Gday all, i was just wondering if a set of VX SS rims will bolt straight onto my VR Wagon? The wagon is lowered (lowest legal) and i was planning on running 235/45/17 tryes? Only reason i ask is because a friend told me the offset is different?? I dont know what hes talking about (whats an offset???), and he said i would need to use spacers (which are illegal apparently) to make it work??? Any help appreciated.
    Verynice's Avatar
    Verynice is offline Band
    VS Caprice 5L
    Aug 2008
    SA - The Backwards State
    Verynice's Avatar
    VS Caprice 5L
    Aug 2008
    oh you might want to get a set of chrome nuts or holden alloy nuts for them, not good to use the stock VR nuts
    1997 VS COMMODORE,1996 GTS-R COMMODORE
    Feb 2011
    NEWCASTLE
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    is it sorta like this what ya thinkin
    Only prob i have with those rims is the offset is way out compared to vn/s wheels. So i run 215's to avoid scrub issues. I could run 225's if i got a shorter swaybar not sure if 235s would work, i doubt they would. given the issues i have with 225's. However the slightly wider track is a welcome additon.
    Reaper
    VK EXEC EFI
    Jul 2006
    Quote Originally Posted by VrWagz1 View Post
    Thanks alot, yes thats exactly what i want to do love that look...... So if your running 215's what profile are you running?
    Also EDGE3 what 18's do you have on your car? VX clubby or something? Sorry just cant picture any of the other models mags but the SS which are 17's
    nathanVY's Avatar
    nathanVY is offline need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    a new set of chrome nuts is definitely the way to go, the standard nuts don't always hold them on properly lol.
    VrWagz1's Avatar
    May 2008
    wollongong
    I run 45 profile, At the time when that shot was taken, 205/45 were fitted, which looked slightly skinny on the rim, but they were a good potenza tyre and worked well. I went to 215's after that and they were fine, plus they fitted the rim nicely. Next i got a set of 225 on the rear, i ended up putting them on the front cause they scrubbed on the passenger side under the gaurd way too much for my liking.
    But a slightly thinner walled 225 may work on the rear. They probably would have on mine if the tyres wernt such a thick wall, plus if i redid my panhard rod bush's it may have made a few crucial mm's difference too. Dosnt help the back is on super lows though aswell, if i had an adjustable panhard rod then i could shift the train back over to the drivers side and the car would be able to run 225's on the rear then. Cost vs benifit really, going 10mm bigger really isnt worth my time friggin around under the car with panhard rods
    Reaper
    VK EXEC EFI
    Jul 2006
    Thnx for all your help, now just to find some rims.......... Ive just done some googling and found out that 215 50 17 will have the same rolling diameter so no stress with the speedo going out as well
    Thanks again
  1. VE SS 18" rims to fit VS Wagon
    By JorDAZZLE in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-09-2010, 09:30 PM
  2. rims on VZ wagon
    By elusive1 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 16-12-2009, 09:46 PM
  3. VX wagon on VE ssv rims
    By neobristol in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-06-2009, 09:37 PM
  4. Vz Rims on a vy wagon
    By mparces in forum General
    Last Post: 07-10-2008, 05:30 PM
  5. VY SS 18x8 rims on vx wagon
    Last Post: 21-01-2007, 04:52 PM
