Results 1 to 5 of 5
Thread: VR V6 Auto Engine light on.
    2002 VY Calais I V6.
    Jan 2011
    New South Wales
    Default VR V6 Auto Engine light on.
    The engine light came on, when i was in the wet and tried to do a very very mild burnout.
    The car seemed to Be stuck in a high gear like mabye 3rd or 4th. tried shifting manually through 1,2,3 and the car didnt change in relation to shifting.. just felt like it stayed in 1 gear.. and after that i got home, switched the my car off. and now it won't start.
    I'm going to do a error code check soon. I'm leaning towards something internals gone within gearbox? battery is fine with a good charge.
    Car has 129'000 kms, 3 week old tranny fluid, and car wasn't running hot when it happened..
    any thoughts??
    Feel free to ask if u need more info.
    Thanks, Carl.
    Considering A Manual Conversion!
    94 VR Executive & 99 VT XU8
    Mar 2005
    Melb
    ^^ error code check - post and see what comes up
    94 VR V6 - No ABS & NO IRS... a true mans steed and a 99 VT XU8 for good measure.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Sounds like it went into LHM after your 'mild' burnout....maybe low trans fluid level....however the no start situation is a bit different as no transmission fault will stop a car from starting.....at least none that I've heard of.
    When you say the car won't start, does it crank, or crank but not fire or what.
    FstStig's Avatar
    FstStig is offline Diagnostician
    1993 VR Calais
    Sep 2008
    Newcastle/Central Coast, NSW
    All fixed guys, turns out his battery went bust after it.... Pulled a Code 75 which was Low System Voltage (Transmission only). Put my Jumper Pack and managed to get it jumped started but even after letting the battery charge for a bit the car would not want to crank. Put my battery in from my Calais and she fired away. Basically how we came to conclusion it was the battery lol
    If it's not a Symptom its not relevant, and if its not relevant I don't care!
    Jan 2011
    New South Wales
    Yea its All good now, i recon it went in limp mode.. Due to the fact that it didnt change gear. Possibly cause of low voltage supplied to the trans?? As code 75 indicated. But yea its good now.. Just gotta sort my alternator issue :/
  1. ENGINE light, ABS light, TRAC OFF light AIRBAG light and OIL light
    By jamierawr88 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-10-2011, 09:06 PM
  2. Vt 5.0 idle problems and missing also engine light and oil light come on
    By vtss5.0 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-07-2011, 07:32 PM
  3. VP auto check engine light code23(?)
    By VN4ever in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-02-2011, 09:22 AM
  4. HELP Engine Light / Transmission light and rough gear changes
    By flash20005 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-10-2010, 03:34 PM
  5. Engine stops, fuel light on, battery light on GOODBYE
    By scarletx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-06-2009, 03:43 PM
