Results 1 to 8 of 8
Thread: slower of the mark now
    vs v6
    Apr 2011
    goldcoast
    Angry slower of the mark now
    my vs executive v6 used to be nice and snappy of the mark but has lost that punch of the mark all of a sudden its had a full service 7500km ago new leads plugs oil only got 76 000 km got any ideas
    1997 VS COMMODORE,1996 GTS-R COMMODORE
    Feb 2011
    NEWCASTLE
    Needs another service,every 5000kms could be the injectors need to be cleaned.Did the transmission get serviced if its an auto?
    GetToDaChopa is offline Blues Brother # 2
    The Blues Mobile
    Dec 2008
    Western Sydney
    Maybe crappy fuel, blocked fuel lines :S something to do with fuel im guessing!
    Cracka is offline Banned :P
    Old Sneakers
    Mar 2011
    Croydon
    7500 kms is a long time, or distance for that matter.
    Remove, clean and refit your plugs.
    Remove and clean the throttle body, be sure to remove the sensors before using any degreaser as it can stuff them up (Throttle position sensor and Idle Air Control)
    Take the lid off of your plenum, plug the inlets with rags, use degreaser and clean rags to clean the inside of your plenum (Not much of a gain unless it is really bad)
    Check your air filter too, oh and remove the engine fuse, try to crank the engine for a few seconds and replace the fuse again to reset your ECU.
    I know that there is allot more you can do, but that is a start.
    FstStig's Avatar
    FstStig is offline Diagnostician
    1993 VR Calais
    Sep 2008
    Newcastle/Central Coast, NSW
    They can happily go 10,000ks without a service, this is what is in the owners service book in 10,000k intervals.... Although a lot of people prefer to do them every 5000ks.
    If it's not a Symptom its not relevant, and if its not relevant I don't care!
    vs v6
    Apr 2011
    goldcoast
    i was thinking maybe the plugs aswell my oldman got it serviced before he gave it to me checked the invoice for the service and they used cheap plugs i will replace them whith a good brand and clean the injectors and check aircleaner a girl hit my car around the same time i got it back from the panelbeaters i notice it slower of the mark i was thinking they usually diconect the battery when they work on them i thought about reseting the ecu because i did drive like an old man when first got it back guess i will find out if it works ive thought it was a bit of a mith that it really works thanks for the info hope it works it used to spin of the mark which i like
    vs v6
    Apr 2011
    goldcoast
    Feb 2011
    NEWCASTLE
    It could possibly be one of the injectors,if you take them out and send them away to get cleaned the car will have its take off power restored
  1. wifes car geting slower and slower
    By Dayvo in forum General
    Last Post: 10-08-2010, 08:04 PM
  2. how much oil capacity is there between the full mark and low mark on a vs ecotec?
    By old mate in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-04-2010, 08:33 PM
  3. Need help vz exhuast droning!! And slower
    By BeKzZz in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 25-04-2009, 04:40 PM
  4. need help my sc14 has made my car slower
    By Matt_vp in forum V6 Development And Modification
    Last Post: 05-11-2006, 02:16 AM
  5. Should school zones be slower?
    By Tasmaniak in forum The Pub
    Last Post: 15-09-2005, 05:20 PM
