Hey guys, i just brought some monroe gt gas shocks for my vs because i got ultra king springs and got told i need new shocks as the ones i got are to big which are not allowing my car to sit low enough.
Monroe - GT-Gas
Did i do a mistake buying them and not these?
Monroe - GT Sport
seems to me that the monroe gt gas stocks dont make your car lower but the gt sport ones do?
anyoneeeeeee?
Gt Sport Are just a better shock they are not shortened
oh ok thanks
It would be better to get shortened shocks aswell but not necessary,the only thing is if you use standard shocks theres a chance they might pop out if you hit a pot hole.And also lowered springs make the car lower not shocks
gt sport are a short bodyed strut and are valved different to suit a lowered coil.
and shocks will not alter height, unless you have a factory hsv 19" wheel strut where the spring seat is 10-15mm higher.
Your springs arent low enough to your liking so get ones that are even lower,once again its not the shocks mate,but like I have said you need to have shortened shocks with lowered springs but people will tell you that it isnt necessary.As glenn l has said get bigger wheels then it will look more lowered
I figured the problem.
It was the shocks!
i got monroe gt shocks and now its just low enough top of the wheel which is perfect
