Results 1 to 5 of 5
Thread: VS Climate Control problem
    VS Statesman SIII 5.0 V8
    Apr 2009
    Default VS Climate Control problem
    I'm sure there is a writeup about this problem, but for the life of me I can't seem to find it at the moment.
    Got a problem with my VS Climate Control. The direction of the air will either be on the windscreen, or on your feet, but won't change to blow on your face.
    I read somewhere that it's a vacuum hose from the engine or something that controls this movement, but if someone could point me in the right direction I'd appreciate it.
    Thanks
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Look down the bottom of the web page you are on now - there is is section called "Similar Threads" which gives links to your problem.
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    Apr 2009
    Quote Originally Posted by hako View Post
    The only similar threads I get are:
    - Stalling when pulling up at the lights (not the same issue)
    - Display won't turn on (not the same issue)
    - Cross on the display (not the same issue)
    - buzzing/grinding sound (not the same issue)
    I did actually try a search for it but came up with nothing... if you do see a topic on it could you paste a link here?
    I was told by the air-con guy that the vacuum hoses from the engine to the air-con have most likely perished which is causing the problem but he was very reluctant to fix it as he said it would be a pr*#$ of a job.. and I do remember reading about it about a year ago or more on here but for the life of me cannot find the posts again..
    Apr 2009
    Actually found this thread with a Google search:
    VS Climate Control Diagonostic
  1. Climate control problem
    By dmbillo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-11-2011, 05:26 PM
  2. climate control problem
    By shaneo vr355 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-11-2009, 03:36 PM
  3. VP climate control problem
    By joebloggs in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-01-2007, 12:24 PM
  4. Climate Control Problem
    By brad_m_is in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-02-2006, 11:16 PM
  5. VS Climate Control Problem
    By KILLERVS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-02-2006, 05:36 PM
