G'day
Lower pacemaker flanges (that bolt to the Y pipes) are scrapping on higher speed bumps (not all of them,but a couple of ones at work even sir edmond hillary would be nervous climbing!!!)not to sure if the bumps are trying to push them towards the rear end of car and eventually weaken/break something.
Car (vs comm) is standard height,exhaust system is done right (not lowered or sagging)
Anyone got any ideads how to lift em up a bit?
i've been tossing around silly ideas in my head...Higher engine mounts to lift height of engine and pipes...raising the car with lowering ( ? ) blocks... going to 235/50/17 tyres instead of 235/45/17 (unsure about the turning circle at front!)...different kind of shockies...???
Anyone got a thought?
Go to an exhaust shop and get them welded straight onto the Y-Pipe? I read that if you let this go it can cause your extractors to crack over time ay so as you said it will eventually weaken/break something and that will most probably be the extractors.
^^ spot on.
94 VR V6 - No ABS & NO IRS... a true mans steed and a 99 VT XU8 for good measure.
What if i cut the flanges (extractor and Y bend) off right at the actual flange,and that would probably leave a 30 mm (?) gap,then get a 100mm long stainless steel pipe/sleeve to go over them -with a 25mm cut lengthways at each end- header/exhaust gasket goo ,then clamp them on.Cos if they're welded on and you had to take them out in future for any reason it would be too damn hard,but this way you'd just unclamp at usual place for easy removal,plus the heat from the weld might weaken the pipe tensity/ceramic coating.
Would anyone reckon in favor of this idea,or would clamping a sleeve be out the question???
I had the same problem. I got them to make up a new Y piece at the shop. Also if you undo the bolts that hold the extractors to the heads, there is a certain amount you can lift the extractors then bolt them back up.
