Page 1 of 2 12 LastLast
Results 1 to 25 of 26
Like Tree3Likes
Thread: Just bought a 93 vr ss
    vr ss
    Apr 2011
    sydney
    Default Just bought a 93 vr ss
    Just bought a 93 vr ss-como2.jpgJust bought a 93 vr ss-como1.jpgjust bought it after saving my money all original even original stereo for 4000.00 only thing not original is the headers and exhaust but sounds awesome just thought id share it
    Big_Simmo's Avatar
    Big_Simmo is offline Great White Cranberry
    WM 6L Stateman
    Apr 2010
    Vr ss & vy v6 wagon
    Jan 2010
    Central Coast, NSW
    looks good,looks like it has vs ss seats in it,the design on the seats is different to a vr ss seat
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    nice ride,,,,,how many km on her
    Quote Originally Posted by rousy88 View Post
    Click image for larger version.
ID:	114457Click image for larger version.
ID:	114458just bought it after saving my money all original even original stereo for 4000.00 only thing not original is the headers and exhaust but sounds awesome just thought id share it
    is it a 185kw v8 (same as my maloo,s v8 see pic)?
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
    vr ss
    Apr 2011
    sydney
    Hangman's Avatar
    Hangman is offline Torana Addict
    2 commys, 3 Toranas and a WB Panel Van
    Jan 2010
    Newcastle, home of Toranafest
    Not a bad pick up for 4k mate.
    Quote Originally Posted by hakhawk View Post
    there are more pressing issues on the site, like choosing between vl's and potatos.
    1997 VS COMMODORE,1996 GTS-R COMMODORE
    Feb 2011
    NEWCASTLE
    Nice car mate but you need to change your wheels around the otherway so the air can cut in on the brakes better,thats why they were designed that way and alot of people dont relise this
    VS Berlina
    Mar 2011
    Woodford QLD
    Quote Originally Posted by EDGE3 View Post
    now thats funny
    Feb 2011
    NEWCASTLE
    vr executive 5.0 M5
    Oct 2010
    wamberal
    Might be funny but 100% true
    good sense of observation!!
    VS Berlina
    Mar 2011
    Woodford QLD
    Sep 2005
    its got 164000 klms
    thats not too bad at all......is the v8 a 185kw?
    Feb 2011
    NEWCASTLE
    DAKSTER he needs to swap the right hand side wheels with the left side,then the curve point of the wheels will then point forward instead of backwards which then has a correct angle for the air to flow into the brakes.
    Sep 2005
    im sitting there loooking at the wheels going ????what you on about????silly me then i took another look and i think you 100% spot on ( i may be wrong) but i realy do see your point.....my maloo wheels(pic in profile) arnt like those so i think mine can go on anyway(just not backwards lol)
    if it was my ss id be changing them around
  15. #15
    VS Berlina
    Mar 2011
    Woodford QLD
    so you change the wheels to the other side.. agreed, they point the other way. Unless the other wheels are different, bring them to this side.. what happens to them?
    Either the car has 2 wheels that are physically oriented in one direction, and 2 wheels that are physically oriented in the other direction ( and I am willing to be corrected should that actually be the case.. ) then moving wheels from one side to the other will have no effect at all. I wonder which side the spare is designed to fit...
  16. #16
    vr94ss's Avatar
    vr94ss is offline walks barefoot
    VR SS '94
    Feb 2009
    Lismore, NSW
    Quote Originally Posted by DAKSTER View Post
    If all the wheels are the same, and I believe they are, then you are right, swapping them side to side will have no effect. I had a quick scan of this thread before heading off to work this arvo and thought WTF are they talking about?
    Edit: Nice car rousy88. Hope you don't lower it
  17. #17
    Feb 2011
    NEWCASTLE
    We have a winner vr94ss,all the wheels are the same so you can not swap them over they will end up the same way,was just trying to see how long it would take for someone to realise this,hope none of you get to pissed off I was just having a bit of fun
  18. #18
    Patti2912's Avatar
    Patti2912 is offline P4TT1
    93 VR S Commodore
    Jul 2010
    St. Kilda
    Tool of the week winner found.
    Quote Originally Posted by Morton View Post
    You're better off using a 175g can of Masterfoods Wholegrain Mustard. I just measured that, and it's 9.5cm tall. Keep one in your car at all times, and if a police officer tries the "coke can test", you can tell him what I told you
  19. #19
    Feb 2011
    NEWCASTLE
    Thanx for that compliment Patti2912,I actually looked further into this situation with these wheels and it turns out that at the start when they made these wheels they actually did make lefthand and righthand side wheels so both sides pointed forward because I was right in that the air cut into the brakes better,they only made a certain amount of them and put them in the added extras category,but they ended up getting complaints that when they needed to be rotated they could only rotate them front to back and not side to side so then they just produced the wheels facing one direction
  20. #20
    VS 5 Litre BT1
    Jul 2006
    ....but they ended up getting complaints that when they needed to be rotated they could only rotate them front to back and not side to side so then they just produced the wheels facing one direction
    No different to directional tyres so what's the problem ?????
    BTW - Nice pick with the new ride.
  21. #21
    Feb 2011
    NEWCASTLE
    Because the rims faced forward they could only be swapped front to back so they would stay pointed forward only on the same side of the car,but the rims that dont have the curve on them can be rotated on any side eg front left to right rear but with OP's wheels design only front left to rear left.But most of the wheels these days can go on any side front and rear.
  22. #22
    VS Berlina
    Mar 2011
    Woodford QLD
    Ummm believe it was the very first post after you made the original statement that someone 'noticed' it when I said how funny that statement was. It just took us a while to help you grasp the concept... not pissed off though, glad to be of assistance
    I'd be interested in hearing from the OP though, as I have said I am willing to be corrected if in fact the wheels are unidirectional. I guess we've lost him though, haven't heard beyond the original post.
    There are such things as unidirectional wheels, but the cooling slots on the ones I have seen are much much smaller. I would assume the manufacturers would prefer you didn't suck a passing plastic bag through your wheels .. oh wait that wouldn't help because the plastic bag could still get sucked in under the car by the wheels if they were rotating the other direction .. oh wait that would mean the brakes get air sucked past them from either outside or under the car regardless of which way they were pointing .. oh damn that probably means the unidirectional ones are just for looks..
    Presenting this information not because I think I am right, but to show how silly it is to make categorical statements as fact without checking first***... I actually have no idea what the purpose of unidirectional wheels are, and I am guessing they probably do help the brakes a little. None of us can make any kind of educated statement on the OP's wheels though unless we have the same set of wheels to check, or can find them online, or the OP comes back and clarifies or adds a photo of the other side of the car.
    I know if I was the OP and blonde enough to try without thinking, I might be peeved if I actually went out and rotated all my wheels on your recommendation, stood back to admire the car and thought 'huh, nothing has changed' !!
    If you knew this and 'was just trying to see how long it would take for someone to realise this' then why continue trying to defend the point?
    *** I admit to having made the same mistake, categorically stating that HID lights were legal because my car passed a roadworthy with them. Of course, they aren't, I just got lucky then made an assumption...
  23. #23
    Sep 2005
    lol well it had me cafudled....................
  24. #24
    Feb 2011
    NEWCASTLE
    Sorry DAKSTER it looks like you are pissed off about it mate I didnt mean to offend anyone but it looks like you have taken this all to heart,if you want to reply to this post which will be my last on this topic then go ahead take out your frustration on me again,its all a bit of fun
  25. #25
    VS Berlina
    Mar 2011
    Woodford QLD
    lol i have no reason to be pissed off, just playing devils advocate. Everyone makes stupid statements, including me.. just enjoying the chance to light the match instead of getting flamed for a change its all good m8..
  1. Just bought a T/T VH SLE
    By saladine1 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 25-10-2009, 05:14 PM
  2. just bought vp ss!
    By Denso in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-08-2009, 01:55 PM
  3. Just bought another VP
    By LTHL-VP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-07-2009, 06:15 PM
  4. Bought VP V8 :O
    By greenfoam in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-01-2006, 10:21 PM
