Results 1 to 2 of 2
Thread: VS Gas stall at 60-90km Idle
    VS Executive S2
    Oct 2010
    Central Victoria
    Default VS Gas stall at 60-90km Idle
    Recent mods MSD Coils and Big mouth CAI car is also recently serviced
    The car runs fine on gas as long as i have a slight amount of pressure on the throttle ( You can see how this is a problem while doing 80km down a hill.. i have to brake and accelerate at the same time ). I have been talking to some people and the only thing we can think of is the gas freezing as a result of the CAI, But with aoutside air 17c I dont see how this would be a major problem, Has anyone else got any suggestions for me? Its only while the car is traveling between around 60km to 90km it will stall if i have no pressure on the throttle ( Runs 100% fine on Petrol )
    Thanks in advance!
    Jun 2004
    The gas regulator..?
    Is it higher than the water bleed on the engine.
    Losing any fluid.?
    Air bubbles go to the highest point , the regulator.
    Vacuum hose on underside of inlet manifold ..check it for movement.
  1. VS V6 Stalls at 90km/h
    By cypher967 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-08-2008, 05:25 PM
  2. my car "jolts" at 90km (like im hitting reflectors on the road)
    By lockmac in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-07-2008, 04:20 PM
  3. Car drops gear at 70 - 90km/h
    By DzRBenson in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-03-2008, 09:49 PM
  4. Steering Wheel Shaking from 90km onwards
    By speedyvn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-02-2008, 06:48 PM
  5. Poor idle then stall
    By Snotty in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-01-2006, 06:31 PM
