Results 1 to 4 of 4
Thread: thermostat
    danz Guest
    Question thermostat
    hi guys & gals im new here and im not sure where i post but anyway,,,i have a vr ute and i just flushed the radiator and cleaned the hoses and over flow bottle out, and filled her up nice clean water and coolant,i just realized i should probably have put a new thermostat in as i think it would be due for one, and since the water was horrid and a little rusty,,anyway i just wondered how much a thermostat is?,and do i have to empty the radiator to put it in? sorry im a beginner i hope i made abit of sense lol anyway if some one could just give me a little run down it would be fantastic,,
    VX V6 /VR V6
    Sep 2005
    stat should cost you 10-15$and gasket2$
    you will lose some coolant when you take the stat housing off you can just top up afterwards.but you probably should have flushed you motor with the thermostat removed as is the only way to properly flush the block.
    good luck
    danz Guest
    Thanks heaps RS2000 for the info,so do u suggest i take stat out,put housing back on,and run it for abit,say around the block or idle,then empy it and put new themostat in and fill her back up with fresh water and coolant, sorry if my questions seem silly,i just wanna get things right,cheers dude
    VX V6 /VR V6
    Sep 2005
    If you really want to do the best job, remove the two drain plugs on the block either side underneath exhaust manifolds and your bottom rad. hose ,then remove thermostat housing and thermostat and run a garden hose into the thermostat housing until you get crystal clear water running out of the plug holes and the bottom hose outlet. Good luck sorry about late reply as I dont get on the forum every day
  1. thermostat
    By pr0n in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-02-2007, 06:58 AM
  2. thermostat
    By ab56452001 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-12-2006, 01:14 AM
  3. Thermostat
    By 10000_fists in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-12-2006, 09:53 PM
  4. thermostat
    By slayer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-10-2006, 10:48 PM
  5. thermostat
    By sully in forum VL Holden Commodore (1986 - 1988)
    Last Post: 06-08-2005, 12:33 AM
