Results 1 to 4 of 4
Thread: Vs exec install berlina dash
    Jake.VScommo's Avatar
    Jake.VScommo is offline fry tires, not clutch
    Vs factory 5 speed v6 wagon
    Mar 2009
    central coast nsw
    Exclamation Vs exec install berlina dash
    Hey guys i hav a vs exec, an i want to put a calais/berlina dash in it, wat do i need to do it? I hav a berlina dash thats out a vp my mate said, im not sure. And he also gave me a level 3 loom. Can i use a vp etc set up or does it hav to be vs loom and dash? Also do i need a trip computer thing to work the electrics in the dash. Any help about this will really help, cheers
    MY RIDE:
    -VS v6 factory 5speed wagon LAY33N - now SXCWGN
    -VP vacationer slammed with 18's and lsd
    Check out my wagon: http://forums.justcommodores.com.au/...on-sxcwgn.html
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    If the cluster part number starts with a K then it will not work for you. You will need a R or S first digit part number. The L3 loom you have hill need to be un taped and the plug set cut out of it. You cut the 4th plug and switch block plug where it joins the main loom. Then graft it into the Executive loom using the instructions found in the "tripin" thread.
    and 3 Dangerous non ABS VN's
    Mar 2009
    central coast nsw
    Ok sweet as well i will hav to check the part number on the cluster first the hav a look at the loom, so by the plug set, do u mean the fuse plugs??..
    MY RIDE:
    VS Executive S2
    Jul 2010
    the 4th connector is the plug that connects to the underside of the cluster (where the LCD's get thier info from)
    switch block plug i believe is the plug that connects to the trip computer unit
    then you run a wire to the yellow/black wire near the ecu
    and thats it! i did mine a few days ago for the first time and got it. thanks to 88GreenVN and makovr. goto the Tripin' thread, it explains everything there..
    ave fuel was so high because i just plugged it in and i only took it around a couple of blocks. its at 16.6 L/100K
  1. How do I install Rear Map lights in my vx exec??
    By holdengirl17 in forum Electrical Wiring / Questions
    Last Post: 01-01-2011, 09:37 PM
  2. pioneer head unit install in vz exec using iso
    By [ASLYVY] in forum Car Audio
    Last Post: 04-06-2010, 08:30 PM
  3. Install Cruise control into Exec.
    By vsspack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-01-2010, 03:29 PM
  4. Berlina dash into exec
    By lowace in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-11-2008, 11:42 PM
  5. '96 VS Exec S2 aftermarket Alarm Install
    By nick88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-04-2006, 11:19 PM
