Results 1 to 14 of 14
Thread: Big screw fell in ecotec motor need help badly :(
    Did have VS Berlina now have VT Berlina
    Mar 2010
    Cockatoo Vic
    Default Big screw fell in ecotec motor need help badly :(
    OKAY so i was taking out the 10mm screw in the top of the motor and one fell down the hole im f**ked how far would it have gone? is there anyway to get it out ? will it #### the motor if i start it ? plz plz help me i dont no what to do
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    something long with a magnet on the end, would have possible gone right down into the head near the valve. You might end up having to take the plenum off to get closer.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Which hole did it fall down exactly? Can you take a picture of the hole?
    Visit my Facebook page
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    Down one of the intake runners I assume? Just go and buy a pick up magnet on a long flexible handle. If you cant find a flexible one then just get a cheap one and bend the curve shape in it yourself. Sacrificing a $5 pick up tool would be worth the effort for the alternative of pulling more apart till you can find it.
    VK Commodore
    Apr 2009
    Quote Originally Posted by cander24 View Post
    This is true. I dropped 2 plenum bolts down the intake hole few weeks back. I was stuffed without it, one was sorta stuck behide a valve stem, so make sure you get a strong magnet.
    nathanVY's Avatar
    nathanVY is offline need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    Muppet of a mate dropped a bolt down one of my plenum cylinders.... got it out with a magnetic screwdriver. good luck.
    just don't start the car til it's out lol.
    Mar 2010
    Cockatoo Vic
    how do you take the lower manifold off as the screw is to deep ???
    Mar 2010
    Cockatoo Vic
    while im taking all these part's off is there any gaskets that i should look at changing?
    hsv91ss's Avatar
    hsv91ss is offline Holden4eva!
    VS Commodore SII
    Jun 2005
    Central Coast
    Mar 2010
    Cockatoo Vic
    OKAY all good now took me like 5 seconds to get it out this morning after a spent like 2 hours looking and trying to get it out of the wrong hole once i realized it was the wrong hole i got it out with a coat hanger and a tiny magnet sticky taped to the end thanks for all your help guy's
    ps i aint doing that again
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    Quote Originally Posted by darcycammo View Post
    Keep it for next time
    Mar 2010
    Cockatoo Vic
    Quote Originally Posted by The1 View Post
    there aint going to be a next time i have learnt to put an old t shirt across the hole's now lol
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    Those bolts in the plenum aren't even meant to come all the way out. its a split thread, so u only need to undo it til its loose and it will stay in the plenum
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
  1. [NSW] fs: vs ecotec motor
    By mitchvsute in forum Parts And Other Items For Sale
    Last Post: 07-06-2011, 08:12 PM
  2. [VIC] wtd- ecotec motor
    By jenkos_vl in forum Swap / Wanted to Buy / Trade
    Last Post: 15-02-2009, 01:13 PM
  3. v6 ecotec motor
    By vn calais manual in forum Parts And Other Items For Sale
    Last Post: 15-10-2007, 08:19 PM
  4. Ecotec motor into a VN?!?
    By HoZy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-09-2006, 03:53 PM
  5. WTB: ECOTEC MOTOR! [Vic]
    By HoZy in forum Swap / Wanted to Buy / Trade
    Last Post: 28-09-2006, 02:45 PM
