Results 1 to 8 of 8
Thread: Does this actually work?
    vs
    Mar 2011
    australia
    Default Does this actually work?
    It says it will give you 17kw power gain for only $87?
    Holden Commodore VS A V6 STAGE 4 performance chip### | eBay
    FstStig's Avatar
    FstStig is offline Diagnostician
    1993 VR Calais
    Sep 2008
    Newcastle/Central Coast, NSW
    About as useless as this thread!
    If it's not a Symptom its not relevant, and if its not relevant I don't care!
    VY SS
    Jun 2006
    Albany
    vs
    Mar 2011
    australia
    vs commodore
    Oct 2009
    Tamworth NSW
    You would be lucky to get 17 kw,maybe 5-10 depending on the condition of the engine and depending on if you use 98 octane fuel or the standard 91 stuff.....If you have an exhaust and extractors and CAI ,and use 98 octane fuel,and the vehicle is regularly serviced etc,then you might see 17 Kw over the standard V6 power rating...I do my own tunes for the VSV6's, and Ive found a tune mostly makes the engine more responsive at low to mid throttle more than anything.In saying that,it does give an overall increase in power,but its just not a real lot..It also makes them better on fuel when cruising around town or when out on the highway....Ive tried hundreds of different tunes now, and I think I have finally found the best that I can get from the ecotec engine in standard form..
    FstStig's Avatar
    1993 VR Calais
    Sep 2008
    for 17kw it would hardly seem worth the dyno run.... How many people are honestly going to go get a dyno done after this just see if it works... Prrrrrrrft be fairly stupid if you do!
    vs
    Mar 2011
    australia
    Quote Originally Posted by Brett_jjj View Post
    all ive got is exhaust done. getting extractors soon and then cai hopefully. after all that i think it will be the write time to buy it
    Patti2912's Avatar
    Patti2912 is offline P4TT1
    93 VR S Commodore
    Jul 2010
    St. Kilda
    Get it mate, i got one similar on my VR that does have a few modifications, air intake, panel filter, extractors, exhaust, cam, and it made a big difference. I wouldn't say it was a huge modification, but it overall has made the feel of my ride much more pleasent. Gears change smoother, excelleration is better with some slight increase down low, and a fairly big increase up high. For the price even if it doesn't do too much, would you really care? Plus the more you modify the car the better it is to have.
    Quote Originally Posted by Morton View Post
    You're better off using a 175g can of Masterfoods Wholegrain Mustard. I just measured that, and it's 9.5cm tall. Keep one in your car at all times, and if a police officer tries the "coke can test", you can tell him what I told you
  1. Speedo/alert won't work - replaced cluster, still won't work
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-05-2011, 10:33 AM
  2. VR 1994 Indicator doesnt work (Hazard lights work)
    By rester in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-09-2010, 01:40 PM
  3. Speedo/alert won't work - replaced cluster, still won't work
    By VS Omega in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-02-2009, 06:54 PM
  4. SWAP: My work for your work!
    By thisispete in forum Swap / Wanted to Buy / Trade
    Last Post: 20-11-2005, 06:55 PM
