Results 1 to 5 of 5
Thread: pushrod query
    vs commodore
    Feb 2011
    Default pushrod query
    After the Vs V6 Ecotec,are later V series ecotecs fitted with same pushrods?
    Am looking at getting yella terra 1.95's (yt6662),they dont come with new pushrods,so am thinking of replacing old ones (car has 278,000 k's) with something newer(?).
    What is the latest model that had the same size pushrods? (ie ,VT, VX, VE, etc)or are they all the same.
    Anyone got a good contact that has yella terra 1.95's?
    FstStig's Avatar
    FstStig is offline Diagnostician
    1993 VR Calais
    Sep 2008
    Newcastle/Central Coast, NSW
    vs - vy are all ecotec thus for using all the same Roller rockers. VZ - VE use Alloytec, different rockers once again.
    If it's not a Symptom its not relevant, and if its not relevant I don't care!
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    As above. However, all the YT V6 rockers i've dealt with require different length to stock pushrods. Are you buying them new from YT? Maybe give them a call to see if you can buy the required pushrods by themself. I've found them really good to deal with in the past and quite helpful.
    FstStig's Avatar
    1993 VR Calais
    Sep 2008
    Yeah should of mentioned I think it was with the VX - VY they were having problems with the rocker it's self hitting the cast iron heads.... Apparently you can grind some of the head away, if you do this make sure you cover up anywhere the bits of metal can get down into the bores.
    vs commodore
    Feb 2011
    Quote Originally Posted by cander24 View Post
    i'll give them a ring and see what they say,anyone know someone there to speak to?
  1. v8 pushrod bent
    By squiblex in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 12-03-2011, 06:51 PM
  2. Centre Bearing Bracket Query & Tailshaft Ends Query
    By Sojourner353 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-12-2010, 07:48 PM
  3. Snapped a Pushrod
    By VPCalais in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-11-2006, 06:19 AM
  4. pushrod to DOHC. Is it possible?
    By SaGe in forum V6 Development And Modification
    Last Post: 30-04-2006, 12:04 AM
  5. pushrod to DOHC. Is it possible?
    By SaGe in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-04-2006, 08:49 PM
