Results 1 to 9 of 9
Thread: The panhard blues
    vs commodore
    Feb 2011
    perth
    Default The panhard blues
    Following directions from this site with my adjustable panhard rod(rear).
    I have centered the diff, however the left wheel is now hugging the gaurd and the right wheel is pushed out to the piont its rubbing.
    Am i supposed to center the diff? To stop the spline chewing out the g/box? Or am i meant to get the wheels even under the guards?
    ve sv6
    Aug 2010
    walesy's Avatar
    walesy is offline Aint no family cruiser!!!
    Cherry Black WH II Caprice, VS exec wagon
    Jun 2005
    Perth SOR
    your supposed to center the wheels under the guards... one side axel is always shorter than the other
    EDIT: glenn l beat me to it
    Going where no late model stato/caprice has gone before.... GAME ON!!
    vs commodore
    Feb 2011
    perth
    okie dokie....
    wheels are pretty even, but the right wheel still rubs. even adjusted left wheel to stick out a little more and right wheel still rubs.
    walesy's Avatar
    Jun 2005
    Perth SOR
    adjust it a little more, if you get it to the point where it doesnt rub but the wheels are spaced too differently take it to a suspension place near you to see what the go is, it could be your wheels are a shitty offset and dont suit the car? which would make them rub even if the diff is aligned correctly
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    If ur running somthing of a vt/x/y/z then the wheels sit out further, not to metion if ur trying to run a wide tyre also. It will be difficult to get the tyres to never rub in this case, all you can do is try to get the drivers side rear wheel over to the outside as far as you can go so the passenger side has room to shift over when the car drops down, but beware if the drivers side lifts, then it will throw the wheel ito the drivers gaurd. Thats just live axle for you though, you need to adjust it to suit your circumstances.
    Reaper
    hsv91ss's Avatar
    hsv91ss is offline Holden4eva!
    VS Commodore SII
    Jun 2005
    Central Coast
    I had mine fitted and adjusted for $40, and the tires don't rub on mine any more on super lows with 18s, even fully loaded no rubbing.
    So something must be up.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Quote Originally Posted by VrWagz1 View Post
    VT-VZ have IRS, no panhard rod so there is nothing to adjust.
    cbr1234mike, the tailshaft angle at the gearbox can never change because it is bolted to the floor at the center bearing. This has a CV joint in it that can operate at greater angles than a universal joint so the diff can't be moved to the extent that it will wear that out.
    Keep adjusting the panhard rod, but do it with the weight of the car on the wheels, not jacked up as jacking it up will push the body over to the left more.
    Visit my Facebook page
    vs commodore
    Feb 2011
    perth
    thanks for feed back guys. this site is bloody awesome. ive learnt an absolute shitload from it.
    i had superlows in the car and now i have ultra lows(in the rear). the wheels are 15x7 pursuits and i think they came out with 15x6's. i think its just going to be one of those things that have to be spot on, within a mm.
  1. VE Blues
    By dtrain in forum VE Holden Commodore (2006 - ?)
    Last Post: 14-05-2008, 10:29 PM
  2. i got the Dead Hard drive blues
    By pow3rslave in forum The Pub
    Last Post: 01-04-2008, 08:05 PM
  3. Gay Bar Blues
    By lgnd3800 in forum Jokes/Humour
    Last Post: 09-03-2008, 08:34 PM
  4. Take that Blues
    By brownie82 in forum Jokes/Humour
    Last Post: 15-06-2006, 12:01 PM
  5. Go the mighty blues!
    By Julie in forum The Pub
    Last Post: 28-05-2005, 08:42 PM
