My dash lights including aircon control lights went out. Changed fuse... no good. Any ideas?
Does the Fuse keep blowing?
Or, when you put the fuse back..nothing happens, and the fuse is still good?
If yes.. The wires behind the fuse slot number may have burned out.. with the engine and all power turned off.. have a feel around behind the fuse slot for anything that can tell if the wire has been broken from it's connection .
Good luck bud !
God help you if the wires have burned for some reason.Had to replace all the wiring in my car, wasn't fun.
nathans VY Calais - 'Calais 2.0' | VT Equipe | VS Calais **SOLD!**
Oh god better ###in not have
Nothing happens checkin wires now
I just noticed key hole light came on but no dash lights. Wiring seems fine
Nah ha fixed it. Changed the parky fuse![]()
all sorted hey that's good to hear! i'm just loving my vs a real pleasure to drive and everything works as it should
I know mine is a utility. Not exclacully a chicks car but I'm weird like that LOL. Yer put correct fuse in... LOL but sounds stupid were the hell does the engine oil go? I'm used to 4 cylinders not 8 LOL still learning where everything goes
Thanks nath![]()
There will be a cap on the drivers side rocker cover.
