Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By hako
Thread: VS tranny problem
    VS commodore
    Apr 2011
    umina beach,nsw
    Default VS tranny problem
    brought a VS a few weeks back for $550 with 5 months rego,
    so i decided to reverse it in the drive way today and there was noo go in reverse at all i had to give it a little, so it decided it would back up slowy and then i turned it off looked on the road and there was a load of fulid on the road( red fulid)
    so jacked my car up and theres no obvious signs of leaks in the transmisson,
    so im stumped any ideas?
    thanks dat
    Zarconia's Avatar
    Zarconia is offline Outrageous Fondler
    96 VS Executive Series 2
    Aug 2010
    Rockhampton
    Red fluid is tranny fluid (Also power steering fluid) so you've likely busted something
    VS commodore
    Apr 2011
    umina beach,nsw
    time to jack it up and have a proper look, how many lines are coming and going from the transmission? are VS tranny problems a common problem
    Zarconia's Avatar
    Aug 2010
    Rockhampton
    No idea mate but id start at the reservoir and work your way backwards. Id put a bit of fluid into the reservoir and see if it leaks from there, if it leaks stationary then there's probably a crack in the line.
    About as common as any other car man
    VS commodore
    Apr 2011
    umina beach,nsw
    thanks mate, cant wait for the rain to clear in nsw and then i get back to work on her
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Best idea is to add 2 or 3 litres of Dexron 3 to the transmission - the fluid goes in thru the fluid level tube which is just to the right of the brake master cylinder. Start with just 2 litres and whilst you are adding it keep looking under the car to see if you can spot where it is draining from. Prime suspects will be the steel cooler lines where they join the transmission, a few loose screws on the pan or the fill tube dislodged. They are the cheap ones. Once you can get enough fluid in her, you can then move it to a spot where you can raise the car on ramps and have a proper look. Good Luck.
  1. Vs bad on fuel and tranny problem!
    By kosij in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-03-2011, 10:56 PM
  2. need help(93 vp tranny problem)
    By 1996_Vs_Commodore in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-01-2011, 10:07 AM
  3. Help Tranny Problem
    By Chirpstr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-12-2007, 12:34 PM
  4. VT series 2 Tranny Problem
    By gumnut75 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-01-2006, 05:02 PM
  5. VT Tranny problem
    By gumnut75 in forum General Discussion
    Last Post: 16-01-2006, 07:54 AM
