Results 1 to 10 of 10
Like Tree2Likes
  • 2 Post By Zeussy
Thread: Toothbrush head in intake hole!!!..D'ohh
    vs commodore
    Feb 2011
    Default Toothbrush head in intake hole!!!..D'ohh
    Cleaning out plenum chamber (in body) with throttle cleaner and a plastic toothbrush and the head of toothbrush has come off and gone 3rd or 4th (looking from front) intake hole (bore?).
    Anyone ever done this?how ya get the mongrel out??? . i've been trying a flexible plastic fuel nozzle duct taped to the end of vacuum cleaner hose,to no avail so far.(might've even pushed it further.)
    1.Where would it end up?a water jacket somewhere as it would be in the cooling system somewhere...
    2.Would removing the welch plugs under the holes flush it out cos i'd imagine a system flush wouldn't get it out...
    3.What would happen if i left it in ? (worse case scenarios),as being plastic it might stay up high as opposed to a bolt that would drop lower...
    4.how bad would it damage the system? (or would it only affect heater system (being in qld,i dont use heater!!)
    5.Would it deteriorate cos of the chemicals in anti-freeze/anti boil ? (seeing as that stuff can ruin paint)
    6.Should i just bolt her back up and not worry about it?(i've just put in 1.95 roller rockers,would there be any strain somehow)
    Any replies would be greatly appreciated as its sunday arvo and am trying to her her back together for work this week
    VY SS Ute
    Jan 2011
    Tried wrapping a bit of duct tape around a stick with the sticky side out?
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    Pull the plenum off, as you should have done to start with and fish it out.
    Zeussy's Avatar
    Zeussy is offline SSM11K
    VY Acclaim S2, VH SLE
    Dec 2008
    Central Coast
    LOL, Sorry but I had to..
    Um, most likely have to pull the plenumn, and Lower Intake Manifold. Depends on how far down it got...
    1. It won't be in a water jacket. It would end up in the intake runners/LIM - Lower Intake Manifold.
    2. Removing the welch plugs won't help.
    3. Worse case scenario would be it getting jammed in between a valve and the valve seat, holding the valve open, then a piston smashing into the valve damaging itself, and or the valve.
    Plastic is no different to metal - it is still affected by gravity,
    4. It wouldn't affect the Heater, its not in the cooling system.
    5. Coolant won't dissolve a toothbrush.
    6. No.
    EDIT: Soop Beat me to it!!
    vs commodore
    Feb 2011
    SUCCESS!!!!!!! Thanks for all help and replies.
    Vacuum cleaner+Garden hose attachment + approx 50mm hose duct taped onto vacuum cleaner pipe so it's airtight.Feed hose right down into intake hole,turn on vacuum cleaner and slowly but carefully pull hose out.Wiorked for me.
    Zeussy's Avatar
    Dec 2008
    Central Coast
    vs commodore
    Feb 2011
    Quote Originally Posted by Skrewdriver View Post
    oops...should have read 50 CM,nice and flexible
    vs commodore
    Feb 2011
    Quote Originally Posted by Zeussy View Post
    Sweet as, good to hear you got it out!
    Could've been a pain otherwise...
    i reckon,specialy on a sunday arvo....good old aussie ingenuity - ya just can't beat it!!!
    Did have VS Berlina now have VT Berlina
    Mar 2010
    Cockatoo Vic
    don't feel to bad over it i did the same thing last week but with to screws lol
    Vs Series 3 Ute, manual. Hz Pano 5.0L injected
    Feb 2008
    Newcastle
    I was tginking about doing the same but taking the plenum chamber off are there any gaskets I need to get if I take it off??
    Cheers, whales
  1. AIR INTAKE MOD COMPLETE - Better than 2-hole mod?
    By adz_vy in forum General Discussion
    Last Post: 28-05-2012, 12:42 PM
  2. ls1 two hole air intake mod
    By vtspeed in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-10-2010, 04:58 PM
  3. [VIC] VY SS intake set up w/ Monaro two hole airbox and GTS maf pipe, various items...
    By Cobez in forum Parts And Other Items For Sale
    Last Post: 29-09-2010, 02:04 PM
  4. Two Hole Mod - Testing Intake Temp
    By mattsv6 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 24-06-2009, 09:27 PM
  5. Hole in head confused???
    By sp4nky in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-12-2007, 03:34 AM
