Results 1 to 4 of 4
Thread: VS Over Run Problem :S
    L67 VS II Statesman (With a SunRoof ;)
    Mar 2010
    Whyalla SA
    Default VS Over Run Problem :S
    Hi everyone, ive got a bit of an issue with my 97' VS Exec,
    basically the story is i had a 5 speed VN that got defected so i picked my self up a cheap roller to drop the motor in, So now i Have the VS running with the Buick and t5 (I dont want you to tell me this is illegal, i dont really care it was its first day on the road today and after numerous issues with spark which are now sorted thanks to a new coil pack, ive noticed it has a pretty bad Over run (The car keeps running for about 2 secconds after the key is turned off) its running the VS Computer and loom, converted into singel knock and 02 sensors running the VS air flow meter so im wondering what could be causing the problem?
    Greg
    Officially In The SunRoof Crew
    '05 VZ Berlina September '09 - April '11
    Mar 2010
    Whyalla SA
    i should also mention when the key is turned off it is not a nice idel, its very rough only just keeping itself runnig before it shuts off
    FstStig's Avatar
    FstStig is offline Diagnostician
    1993 VR Calais
    Sep 2008
    Newcastle/Central Coast, NSW
    Ummmmmmm how is a VS ECU and Loom running a buick motor? Change the ECU and Loom over from the VN.
    If it's not a Symptom its not relevant, and if its not relevant I don't care!
    nathanVY's Avatar
    nathanVY is offline need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    Throw the buick in the bin and put an ecotec in there.
  1. [VR-VS] How To: Fix the VS V6 4 Wire O2 sensor earth problem – Known Holden Problem
    By ephect in forum Holden Commodore How-To's
    Last Post: 17-01-2012, 11:25 PM
  2. VK v8 breathing problem/oil pressure problem
    By Bookanun in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-12-2010, 03:02 PM
  3. idle problem, very difficult to find problem
    By calais s2 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-07-2010, 10:51 PM
  4. vent problem and horn problem
    By plasmid2 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-06-2008, 10:53 PM
  5. Pt 2 cold starting problem - Is my ECU the problem??
    By manfred in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2007, 09:56 PM
