Results 1 to 7 of 7
Thread: transmission problems
    vs executive
    Mar 2011
    Default transmission problems
    hi everyone
    today i changed from reverse to drive in my vs v6 and it normally takes a few seconds to engage into drive ( as it has done 240 thos ks ) but today it clunked into drive very hard and as i took off it never changed from whatever gear its stuck in it goes up to 80 -90 ks in this gear and revs hard i tried manually changing but to no resolution
    was wondering if anyone knows about this problem and what i could of done to my transmission
    thanks
    VZ SVZ
    Apr 2011
    sydney
    I'm not 100% but something similar happened to my mate before, sounds Like the gear selector is shot or you have striped the gear selector bolt .
    Not 100% though
    vs executive
    Mar 2011
    yeah ive heard this problem too but 1 month ago i had the auto reco'd and shift kitted obviously they would have picked up on that yeah? hopefully
    vn calais 5.0
    Jun 2011
    victoria
    If it was recoed then take it back and ask them to fix it.. How long is the warrenty for?
    VR Executive 93
    Feb 2011
    Queensland
    try and run a diagnostic test and see what error codes come back. There is a process in this site I think its in the how to area. This should give you a better idea on what you may be dealing with
    HSV VT MANTA
    Jan 2010
    Mine has this problem, not the clunk but the lag between reverse and drive and vice versa. I read somewhere that the shift solenoid maybe be screwed. I can't remember which one, i think it may have been the 1-2 solenoid
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    It's normal to have a few seconds delay between N and D - it even warns about this delay in the owners handbook.
  1. vp transmission problems
    By randallbass in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-06-2010, 05:39 AM
  2. Transmission Problems...
    By Bob129 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-01-2007, 08:48 PM
  3. Transmission Problems
    By VT_Boi in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-10-2006, 02:54 PM
  4. VN V6 TRANSMISSION Problems
    By Grantis1976 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-10-2006, 03:12 PM
  5. Transmission problems??
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-02-2006, 11:19 PM
