Results 1 to 5 of 5
Thread: VS Air-Con Q. :)
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    Red face VS Air-Con Q. :)
    Hey fello car lovers
    Have a question.. Most likely nothing.. But I may aswell ask !
    Ok, so when I have the A/C on.. It doesnt seem to push much air through all the air vents.. Even tho it's turned on MAX.. And yes, I've made sure the vents are open LOL!
    Just seems like, it's noticeably weak..compared to me ol' VP..
    I suspect it's just the compressor getting old most likely .
    second Q - With the A/C still on.. And accelerating to roughly 70'ks or more (With a bit of force).. the aircon stops blowing..and goes through the foot wells.. then when the revs slow down, the A/C blows via the vents again LOL!
    Most likely worrying about nothing.. But i love the VS to much not to care hehe ..
    All helpfull post's I'll give + Rep
    Paintball.. It's not just a Sport.. It's a lifestyle!
    Check out my VS Wagon !
    See my Re-Mixes here YouTube - Dtek5
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    First thing is that lack of air coming out of the vents will have nothing to do with the compressor which pumps/compresses the refrigerant, not the air.
    Second thing is that it appears you have a vacuum leak somewhere....this can cause the flaps inside the heater/aircon unit to stick and/or not open fully PLUS when vacuum is low as in when you are accelerating the vents fail to operate and the air gets pumped out the footwell.
    Things to check - vacuum reservoir ball under passenger side headlight - it's a black plastic ball with a vacuum hose going to it - it's job is to hold vacuum which is needed to keep the air flaps open when accelerating (whick is a low vacuum scenario). Check the ball is not split and the vacuum hose is not split/perished. Next check the vacuum line from the bulkhead end of the inlet manifold to the bulkhead....check for splits...there is also a 1 way valve in the line there - check this works. The vacuum hose goes thru the bulkhead to the vent position dial and the heater switch...see attached pix...check vacuum lines are there. Under the bonnet there is also another vacuum line that goes to the heater tap just under the master cylinder....check that.
    I'd say 90% sure low vacuum is your problem......and should be an easy cheap fix. Good Luck.
    Attached Thumbnails Attached Thumbnails VS Air-Con Q. :)-vacuum.jpg   VS Air-Con Q. :)-hotvacswoff.jpg   VS Air-Con Q. :)-heater-vacuum.jpg
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    fully agree with this comment( vac)
    Quote Originally Posted by hako View Post
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    Ahh, legends
    Thank you very much !
    Shall tinker in it this arvo !
    +Rep coming for ya's :P
    96 vs calais series 1
    Apr 2011
    maroochydore
    take some pics of the broken part when ya find it, great to share the knowledge brother.
