Results 1 to 21 of 21
Thread: VS Suspension Change
    1997 VS Berlina
    Apr 2011
    South Sydney
    Default VS Suspension Change
    im looking to change my VS's suspension mainly to better ride quality. i want to stiffen suspension and lower it slightly roughly 20mm and 30mm rear. whats a good setup to achieve this? it still has stock suspension atm
    cheers
    1997 VS Berlina
    Apr 2011
    South Sydney
    would low king springs suited to my car and monroe gt sport shocks work or would it be lowered to far?
    nathanVY's Avatar
    nathanVY is offline need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    better ride quality and lowering don't go anywhere near each other. if you want it to ride better, put stock 15s on with really good tires (pirelli or the like), new struts and shocks all round, maybe new springs and bushes if you're still not happy.
    1997 VS Berlina
    Apr 2011
    South Sydney
    well i want a stiffer ride i should have said sorry its like a boat in the corners swaying all over the place. i want more performance than comfort
    VS Executive S2
    Aug 2010
    melb
    It'll be stiff, no doubt about that. As soon as you lower it a little the ride will be stiff, bumpy and firm.
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    Ahh well in that case go lovells lows (slightly lower than king lows) all round (different heights in the front and back apparently make your steering a bit funny.... although mine has low front and sl back and I can't tell the difference )
    with KYB or Monroe GT sport shocks and struts. Say goodbye to body roll.
    A bicycle
    Aug 2009
    Gippsland, Victoria
    i would be going a set of kings lows or similar with a quality set of shocks, kyb agx or a set of koni's plus a set of swaybars, for good street handling. dont forget good tyres though.
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Quote Originally Posted by NonStick Squid View Post
    @old mate you drive a vs ute therefore you're a bogan therefore your point is invalid
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    1997 VS Berlina
    Apr 2011
    South Sydney
    how much would that setup lower it? i only have a certain amount of room before im sitting on the tires and i want a small gap i dont want it super low or anything
    1996 Vs Berlina
    Dec 2010
    narre warren
    If your interested I'm selling a set of FE2 rear springs out of my berlina for 50 ONO apparently they lower the car around 30 mm
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    id also put a strut bar in the engine bay i had this on my old ute( bloody thing in the end drove like it was rails the strut bar helps tighten up the front end just that little bbit more,nolathain make a good 4 point 1 for the vs
    Quote Originally Posted by old mate View Post
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    King lows drop it about 30mm, Lovells i think are 35-40mm.
    Keep in mind being new springs they will take a month or two to settle and will sit slightly lower after they settle.
    Super low is 50mm+
    A bicycle
    Aug 2009
    Gippsland, Victoria
    once you go too low your steering/suspension geometery will go out the window and your handling will suffer. also, going too low will give you a too high spring rate to have good street handling.
    1997 VS Berlina
    Apr 2011
    South Sydney
    yeah ok wb standard king springs with monroe gt would that lower it much or at all cuz the shock may help lower it a little and thats all i want
  15. #15
    1997 VS Berlina
    Apr 2011
    South Sydney
    where would i find a strut bar? im also gonna replace the rubber bushes would i pick them up from holden or just like supercheap or something?
  16. #16
    vs berlina s2
    Apr 2011
    regents park
    i wouldnt get king springs unless you can get them for cheap i had some lowered kings in my old vs and sure it was stiff and handle good when i first put them in but went soft within a few months, ive also had mates with this problem
  17. #17
    1997 VS Berlina
    Apr 2011
    South Sydney
  18. #18
    vs berlina s2
    Apr 2011
    regents park
    haha yours is newer than mine lol, i guess pedders or lovells would be good ive only ever had a lowered car once and that was my old vs with the king springs but have been told pedders and lovells are good
  19. #19
    1997 VS Berlina
    Apr 2011
    South Sydney
  20. #20
    hsv91ss's Avatar
    hsv91ss is offline Holden4eva!
    VS Commodore SII
    Jun 2005
    Central Coast
    I find Pedders Sports Ryder springs to be firmer then kings, I have Pedders sports Ryder with Monroe GT all round and it does feel smoother and much less bounce then my mate who also has a VS on King Superlows with same shocks.
  21. #21
    1997 VS Berlina
    Apr 2011
    South Sydney
    ok thanks for that hsv91ss ill look into them
    cheers
  1. Looking to change suspension on Calais.. do I go Pedders?
    By 96 Calais in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-11-2010, 10:22 PM
  2. VX Rear suspension crossmember mounts, how to change?
    By bandit10 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-11-2010, 04:11 PM
  3. suspension change over
    By simon-t in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-07-2010, 08:08 PM
  4. suspension change
    By Mr fixit in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-04-2009, 08:41 PM
  5. wanna change front suspension myself.. help?
    By beefcream in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-05-2006, 05:59 PM
