hey guys i was just wondering if there is any way to get my speedo to work on my 1994 vr berlina because i have just put a manual conversion in it but i dont have the manual ecu or manual wiring loom have hooked up speedo with 12v to the pink with blue wire and ground to the black with white wire and the signal wire to purple and white but it still dosnt work ive check the speed sensor and that works fine my dash cluster works fine checked all fuse the all work fine ive done it to a vp before and it all worked fine and also i was wondering if any one had the wiring diagram for and vr berlina and a vx berlina if so can you plz email the diagrams to k.p.saunders@hotmail.com cheers kevin
