Results 1 to 2 of 2
Thread: 97 vs gearbox High rpms?
    1978 hz
    Feb 2010
    Default 97 vs gearbox High rpms?
    G'day guys I have a 97 vs and have noticed that when it changes from first to second ( Its a automatic by the way ) it will change at about 3000 to 3500 I was wondering if that is a little high it doesn't do it all the time and just seems a little odd I had it flushed and service early last year any help to figure out what's up will be much appreciated
    Mark
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Change points will vary according to engine temperature - changes later when cold....economy or power setting - power setting changes later. How far you have the throttle open naturally.
    May pay to check fluid level as well - if full and pink then OK....if brown/burnt then not OK....also could just be something in the valve body sticking....or the transmission getting old and worn.
    Good Luck.
  1. Replies: 5
    Last Post: 15-11-2010, 01:04 PM
  2. rpms increase and stick when changing gears
    By Red_Demon24 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-06-2010, 06:13 PM
  3. average RPMs
    By LightningVP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-11-2008, 05:40 PM
  4. Gearbox stuck in high gear!
    By ecotec_powa in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-01-2008, 08:20 PM
  5. VN V8 RPMs with 3.45 diff gears?
    By Lexx in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-12-2005, 02:52 AM
