Page 1 of 2 12 LastLast
Results 1 to 25 of 28
Thread: Worn out Ecotec's
    96 VS Wagon
    Mar 2011
    Nth Brisbane
    Default Worn out Ecotec's
    Having only recently purchased a 96 VS wagon and now had it on the road for a month, I figure the engine is stuffed! It was full of oil on the dipstick when I drove from Brisbane to Coolum the other day return, but was on the add line when home.
    It blows major amounts of blue smoke from the exhaust particularly when you floor it from the lights.
    Well actually, the thing is you can't just floor it from the lights as such, unless you want it to spin madly off the mark and then chirp into second gear.
    The auto has a problem with a logged error code and the symptoms of the problem is 1st and 2nd gear changes are very quick and abrupt. 3rd and 4th changes very smooth.
    Anyway, I started this thread wondering others experiences with the ecotec's performance when the rings and probably valve stem seals are worn out.
    I have raced another ecotec that makes no smoke and the difference in performance is bugger all.
    Interesting that power does not seem to drop off even though the engine needs replacing a long time ago considering the amount of smoke it blows.
    VK -Project-, VX R8 Clubsport
    Feb 2010
    Tamworth NSW
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    could be stuck pcv letting oil in the intake, worn rings. Automatic could be 1-2 accumulator piston/broken spring, worn valve in the valve body or stuck check ball in the separator plate.
    Feb 2010
    Tamworth NSW
    Quote Originally Posted by The1 View Post
    that would make the most sence
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Could also be running too thin an oil - normally they use 20W50 but with wear you can take it out to 60 or 70. Also if the car has not had an oil change for a long time or has done a lot of short runs the oil will get diluted and then a long run will burn it off.
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    95 VS Calais
    Apr 2011
    Central Coast
    My mechanic told me that mine is burning oil because my valve stem seals are gone, i go through a 5l bottle of oil a year just topping it up every now and then when the oil light on the dash comes on, been doing this for the 3 years i've owned it.
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    To test for wear.. do a compression test. If its low and adding a teaspoon of oil to the cylinder raises the reading by a decent amount, then its worn rings, If the oil doesn't change the readings then its probably leaking through valve seats/faces.
    As you said, the leaking oil into the combustion chamber and out the exhaust is probably valve seals or excessive stem to guide clearance, the vacuum created by the intake stroke sucks oil down the valve guide from the rockers. Your rings would have to be shot to the shithouse (and have shitty compression) to be letting that amount of oil through, so I doubt its ring wear because you mentioned that it's power is still on par.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    VS Berlina soon to be 5L
    Aug 2010
    Girrawheen
    96 VS Wagon
    Mar 2011
    Nth Brisbane
    Quote Originally Posted by 1FATVT View Post
    how many km's the donk got ?
    The speedo says 396,000 but it does not count up any more and who knows how long it has been like that.
    Is there a way of checking whether the PCV valve is functioning correctly?
    I do have another VS that has a really good auto that was rebuilt recently at a cost of over $2k. The engine that it is attached to it blows a bit of smoke when it is cold but the smoke goes away after 4 or 5 minutes of following it along the road as it warms up.
    I dare say I will just plonk the whole engine and gearbox into my wagon. Picked up this other VS for $300
    Quote Originally Posted by Vee-ard View Post
    Yes, this is the go, but the compression tester I have won't fit most of the plug holes without fouling the body or accessories. Need one with a flexi air hose on it I think.
    I will do a compression test out of interest, but it is using a litre of oil at 100klm/h highway travel per 120 klms which is way too much.
    Cheers for the thoughts and ideas all.
    Vr ss & vy v6 wagon
    Jan 2010
    Central Coast, NSW
    Quote Originally Posted by Paul13pp View Post
    an ecotec with 396,000kms?
    96 VS Wagon
    Mar 2011
    Nth Brisbane
    Well.... my thoughts exactly !!
    Thus why I asked whether the ecotec's loose their guts when the engine is worn or not.
    nathanVY's Avatar
    nathanVY is offline need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    VL Commodore
    Dec 2008
    How much guts should they have? Mine doesn't chirp the wheels when you floor it at the lights
  15. #15
    Hangman's Avatar
    Hangman is offline Torana Addict
    2 commys, 3 Toranas and a WB Panel Van
    Jan 2010
    Newcastle, home of Toranafest
    Quote Originally Posted by Z2TT View Post
    Mine either unless my other foot is on the brake. And mine has 130,000k's on it, give or take.
    Quote Originally Posted by hakhawk View Post
    there are more pressing issues on the site, like choosing between vl's and potatos.
  16. #16
    96 VS Wagon
    Mar 2011
    Nth Brisbane
    Well this wagon does. In fact I find it hard to drive without leaving black marks everywhere after driving an old Ford XF for years.
    Seriously though, if you floor it from the lights, it spins and revs madly then chirps into second. By this time you are doing about 80 klm/h in a short time.
    It has standard wheels with rather old tyres and I dare say this is why it has little traction and spins so easily.
  17. #17
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
  18. #18
    Hangman's Avatar
    Jan 2010
    Lol, mine has stockies on it, but the tyres aren't that old.
  19. #19
    VS S-Pack SII
    May 2008
    Did Anyone think to take notice that it's a wagon? Don't they run LIVE axle and not IRS... which, as far as I know, spin a LOT easier than IRS...
    And given that a VN commodore can spin the wheels with the old buick motor (Because it was live axle), it would make sence that the ecotec, (rated with more hp) would spin the wheels even easier?
    yes??
  20. #20
    Hangman's Avatar
    Jan 2010
    My sedan is live axle.
  21. #21
    VS Stato l67
    Mar 2009
    Melb
    Spinning wheels in a live axel V6 isnt a sign of good power, its a sign of poor traction.
    Id put a second hand engine in there and some new tyres, then sell your old engine to get back some of the cash
  22. #22
    VS S-Pack SII
    May 2008
    Quote Originally Posted by monkeys437 View Post
    I never said it was... if you read what i said, it was because it was live axle, not because the ecotec has more power... my reference to the ecotec having more power was implying that it would spin a live axle wheel easier than a buick.
  23. #23
    crazywog's Avatar
    crazywog is offline VS V6 ECOTEC KING
    my fully shick holden bro
    Oct 2006
    In my fully shik holden bro
    lossing traction in a non irs and in a irs is not the point, its the driver regardless of irs i know with mine its IRS/ABS and i can spin like crazy in the wet forget it, its all over the place from gutter to gutter.
    RAJAB RACING
    FullBOOST
    PRESTON AUTOMATICS & DIFFERENTIALS
    etstreet.com
  24. #24
    VS Stato l67
    Mar 2009
    Melb
    Quote Originally Posted by PanthaVS View Post
    What are you talking about mate? I didnt quote you in my post and was in no way referring to anything you had said. In fact i hadnt even read your post when I replied.
    I was referring to what the OP said. He seemed to be eluding to the fact that because there was still plenty of wheelspin, that the engine hadn't suffered from a significant decrease in power. That was my interpretation anyway.
    A live axel open center diff could probably break into wheelspin off the mark even if the engine was down to 80-100 fwkw if it had rubbish tyres
  25. #25
    elmaso's Avatar
    elmaso is offline PARTY AND BULLSHIT!
    VR Calais
    Jul 2010
    there was a bloke on this forum whos got 700000+ out of his old ecotec, hes wreaking it now though, lol
  1. Worn lifters ?
    By lil_mickey in forum V8 Development and Modification
    Last Post: 14-04-2010, 11:27 PM
  2. Are Ecotec's from VS thru VX all the same?
    By greenacc in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-02-2009, 04:49 PM
  3. What is the ecotec's weakest link?? pistons? rods? heads? crank? pins?
    By galeryz213 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-08-2008, 10:23 PM
  4. AFM may be worn out
    By rustman in forum VL Holden Commodore (1986 - 1988)
    Last Post: 09-10-2007, 01:05 PM
  5. Twin throttle set up for ecotec's
    By hoarey85 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-05-2006, 09:09 AM
