Results 1 to 3 of 3
Thread: Timing chain oiling
    VN Berlina
    Nov 2009
    Default Timing chain oiling
    I've just had the need to pull down a freshly built motor for my Commodore rally car.
    The timing chain was totally dry and of course I need to find out why. I've prefiously removed the balance shaft and blocked the oil feed to the balance shaft front bearing, but I wouldn't think this would be the culprit. Where does the timing chain get it's oil from?
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    the 3800 don't have a oil feed for the balance shaft.
    timing chain is oiled by splash lubrication. have you blocked any oil return holes anywhere?
    Body by Holden, Soul by Brock
    the Legend will live forever
    VN Berlina
    Nov 2009
    Sorry my mixup. The front balance shaft bearing is a ball bearing race splash fed and the rear is a pressure fed white metal bearing. So removing the shaft and front bearing should have only let more oil get to the chain. There is only around 1500km on that chain and it's stuffed. Splash fed from where? Cos it looks pretty hard to get splash to it.
  1. [Ecotec] Timing chain and cam
    By 2DIE in forum V6 Development And Modification
    Last Post: 23-12-2010, 11:23 AM
  2. [308] 308 to 355 timing chain . Help please .
    By Fusion in forum V8 Development and Modification
    Last Post: 21-12-2010, 09:20 PM
  3. vn v6 timing chain?
    By steveabbott in forum V6 Development And Modification
    Last Post: 10-05-2009, 05:20 PM
  4. HSV double-row timing chain vs timing gears
    By savage1987 in forum V8 Development and Modification
    Last Post: 05-10-2007, 12:04 AM
