Results 1 to 10 of 10
Thread: vt supercharged motor into a N/A vs series3 ute wat do i need for this?????
    Vs
    Apr 2011
    Default vt supercharged motor into a N/A vs series3 ute wat do i need for this?????
    vt supercharged motor into vs series3 ute wat do i need for this????? can i use the loom off a vs supercharged car on the vt one?? please add anything to this tread that u would think i will need to no.
    Vs Series 3 Ute, manual. Hz Pano 5.0L injected
    Feb 2008
    Newcastle
    Im guessing its a 6 pot? As far as I know it should be all good correct me if im wrong....
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Quote Originally Posted by Nathsp2 View Post
    You can actually use your standard loom and just extend a few wires... you need to drill and tap the LIM for the vs temperature sender, and you need the VS passenger side engine mount bracket.
    Power is measured in DECIBEL
    Vs
    Apr 2011
    Thanks guys do I need to use a supercharged models ecu or the standard N/A will work and I read alot about the memcal does this need to be changed
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    if your vs already has 16210672 pcm then just change the memcal, vt uses 16233396 for n/a and super6
    Vs
    Apr 2011
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    Vs
    Apr 2011
    Vs
    Apr 2011
    Quote Originally Posted by The1 View Post
    hi mate i asked this question awhile back im doing the engine change over and my PCM is a 16269018 can i use this still and change the mamcal over. thanks for your help
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    you need to read the service number not the serial number. You can download the memcal id tool in my sig, it has all the service numbers in it for each model
  1. VT supercharged motor into a vr wagon??? will it fit?
    By CHA53R in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-10-2010, 08:47 PM
  2. VX L67 Supercharged motor into VS
    By Gunzero in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-02-2010, 12:00 AM
  3. [NSW] Supercharged L67 Motor
    By Kernal in forum Parts And Other Items For Sale
    Last Post: 01-07-2009, 10:57 AM
  4. a few questions about the supercharged motor
    By sv9946 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-04-2007, 02:38 PM
  5. supercharged v6 motor
    By wizza in forum Swap / Wanted to Buy / Trade
    Last Post: 01-09-2006, 05:57 PM
