Results 1 to 8 of 8
Thread: Fuel warning lite
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    Default Fuel warning lite
    SMALL PROB>>>after replacing every last bulb behind dash> i now dont get the fuel warning light to glow?(yes its also a new bulb) i still get the warning tone,just no light.......any ideas......cheers in advance
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
    Sep 2005
    evrey other light works.....just the 1 in the fuel warning light.....and yes i check and its not a faulty bulb.....its got me buggered? i changed all bulbs as my power light had gone....now the blooody fuel lite aint a working.i did em all aircon,all behind dash,,,even anew 1 in the cig lighter.....not 2 worry
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Quote Originally Posted by justbad4you View Post
    SMALL PROB>>>after replacing ever last bulb behind dash> i now dont get the fuel warning light to glow?(yes its also a new bulb) i still get the warning tone,just no light.......any ideas......cheers in advance
    If the globe is not working - and the chime is - then it's simply not making good contact or the copper track on the cluster is broken (asuming that nothing ewlse in the wire loom has not been damaged)
    and 3 Dangerous non ABS VN's
    VL Commodore
    Dec 2008
    It seems that the Fuel light is grounded by the "Speed Alert" module, this should be the one on your dash
    Try replace the Speed Alert module with another one and see if this helps.
    Sep 2005
    Quote Originally Posted by 88GreenVN View Post
    88 id be going with what you say.....as when the chim when of today i kinda did the holden dash slap just above the fuel light and it came on....so i say your 100% spot on with the globe not making good contact on the copper track.....the tap on the dash may have fixed it lol if it does it again ill pull out the globe and give it a clean........thanks 88greenvn( pos rep sent yourway)
    VB SL/E
    Dec 2008
    Sep 2005
    Quote Originally Posted by VR38 View Post
    The holden dash slap lol.
    yeah the old slap...........still working ( no more slapping needed lol) still got to slap when fuel is low
    96 vs calais series 1
    Apr 2011
    maroochydore
    buy a cheap multi-meter from jaycar/dicksmith and test the bulb/bulb holder. use the 12volt dc setting and continuaty setting on the meter. easy!!!
  1. [VIC] Auto Meter Pro-Comp Ultra-Lite Air/Fuel Ratio Gauge - Electric
    By LOWPSI in forum Parts And Other Items For Sale
    Last Post: 25-06-2010, 12:40 PM
  2. Ve sv6 low fuel warning
    By sportsmodelsaustralia in forum VE Holden Commodore (2006 - ?)
    Last Post: 05-03-2010, 09:34 AM
  3. Brake warning lite,whats it for?
    By leslloyd in forum VL Holden Commodore (1986 - 1988)
    Last Post: 09-11-2008, 12:04 PM
  4. Fuel low warning
    By SPack in forum VY Holden Commodore (2002 - 2004)
    Last Post: 16-03-2006, 10:23 PM
  5. Fuel Gauge - Low fuel Warning
    By DUMPD_VP_CALAIS in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-02-2005, 07:08 PM
