See the second last pix - the tip of the gun is where you start, then go all round the seal. Don't skimp...just remove excess after the window is in place....basically apply sealant wherever the window meets the body.
Plenum bolts 10-14nm
Inlet manifold - 1st go 3-6nm 2nd go 12-18nm.
