As in label each switchs wires, where they go, what they do? In order to bypass the window module and run a bypass setup.
Trying to hook up power windows, so i need to know what each wire is. I dont have a module so im just going to give it straight power. But i cant do this without knowing whats what.
i took the setup out of a Vs statesman series 2. I want to put it in a vs exec series one. So it wont plug into the bcm so i cant use the module. i want to wire it up with straight power.
Multimeter them?
Altho I think i have seen a diagram for it around here. Maybe in the conversion thread How to install Power Windows or from searching around but it was on this fourm.
The Daily VN T5V6
355 VN GRP A REP
Found it,
The Daily VN T5V6
355 VN GRP A REP
thanks mate but im after something different. i need to supplement the wires to the module. but with what? are they just for power?
Well if you know what the switches do hooking up stright power should be easy, looking at those diagrams its pretty self explanatory.
The Daily VN T5V6
355 VN GRP A REP
i dont think i would have created this thread if i thought i could use the wiring diagram from the sticky thread ' how to install power windows '.
Or are you saying i can? How? If you understand it then explain it to me.
Do i just hook everything up the way it is in the VN VP setup but instead of running wires to module supplement them for 12v power source?
I really have no idea how to tackle this job.
You wouldnt be the first to have created a thread without looking.
But really, you have 12v -> switch -> power window reg -> earth. Dosent matter what car diagram your following there pretty much the same tell up to what controls it. (BCM/PWModule)
Use the first digram in that post. Put 12v to O/Y (orange with a yellow trace )wire coming out of the front switches, and earth the black wire. You also need to move the RHF side reg to directly connect up to the switchs and not the module, its hook up to it so you have your auto window down. All PW switches and regs have the same connectors VN-VS, well all the ones ive swapped.
The Daily VN T5V6
355 VN GRP A REP
