Results 1 to 8 of 8
Thread: my vs ss surges when driving and the tacho flickers. has it happened to you?
    VS SS 5.0
    Apr 2011
    bendigo
    Default my vs ss surges when driving and the tacho flickers. has it happened to you?
    i have tried many things, plugs, leads, oxy sensor, alt brushes, new injectors and still it surges and gettin worse over the last few months. causing it to be heavy on fuel. PLEASE HELP ME : (
    VS UTE, HT MONARO REBUILD
    Dec 2010
    mate my S3 V6 VS ute does this, i changed my leads and plugs which helped and now it only occurs every now and again, but i do have a miss fire that i think might be linked to the problem, Im thinking its my coil packs/ DFI module as every other component is in great working order, it does chew up a bit more fuel than a motor in perfect working order due to the miss fire but it's not real heavy on fuel.
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    Just fixed a similar problem on my VN. Replaced the dissy as the clip that was holding the hall effect sensor had corroded, allowing the sensor to shift around everytime i hit a bump.
    My symptoms: loading it up at low rpm it would cough and splutter then clear out, it would miss when hitting bumps in the road AND the tacho would jump 1000rpm when it did this
    Now its all good
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    VS SS 5.0
    Apr 2011
    bendigo
    any chance the computer is the problem or crank sensor? it doesnt stall, backfire or not start though
    GTP 85's Avatar
    Aug 2006
    Just try swapping the dissy. It a 10 min job. If its not the problem, then you have crossed one thing off the list
    VT SS
    Oct 2009
    shepparton, victoria
    ive got the same problem in my vt 5lt. sometimes its worst then other times.
    and yer when taking off from a standing start it revs nearly drop 1500 rpm from round 3500 to 2000
    ive tried a few things like leads plugs injectors.
    think i mite try a the dizzy.
  1. Engine surges on deceleration
    By maldotcom2 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-04-2009, 12:12 PM
  2. Headlight flickers when indicators used
    By VLishes in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-01-2006, 09:23 AM
  3. Oil light flickers when engine hot.
    By riverrat321 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-01-2006, 11:00 PM
  4. 3-Window Instrument Cluster flickers!
    By zacz in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 21-10-2005, 12:04 AM
  5. engine light flickers
    By scorpiongh80 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-03-2005, 10:55 PM
Tags for this Thread
