Results 1 to 4 of 4
Thread: VS , V8 Idle Problems
    Dec 2009
    Default VS , V8 Idle Problems
    Hello Holden Lovers.
    Just recently I've been having High Idle Problems during driving and when stopping. The problems happen when the car is up at running temperature. When performing a gear change, the idle only drops to around 1200rpm, when I pull up to a set of lights the idle will still be around 1200rpm but slowly drop back to a normal 600rpm. If I remove the Intake Filter, the problem disappears? Has anyone had similar problems?
    1999 VS, Series III, V8, Manual
    Kind Regards
    Rob
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    Dec 2009
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Had similar idle issues once, the fuel hose was loose on the passenger fuel rail in my case. But i had alot of hunting at idle aswell, but i drive a manual too so my idleing will differ to yours.
    Reaper
  1. [LS1] Idle problems
    By 17UCK! in forum LSx Development and Modification
    Last Post: 28-10-2009, 06:30 PM
  2. idle problems. won't sit at a constant idle.
    By macksvt in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-10-2009, 07:59 PM
  3. idle problems
    By leigh 7005 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-08-2009, 12:22 PM
  4. Problems with idle...
    By SAMO-87 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-08-2008, 04:16 PM
  5. idle problems???
    By burkler in forum VL Holden Commodore (1986 - 1988)
    Last Post: 24-03-2008, 09:10 PM
