Results 1 to 13 of 13
Thread: Crane Cam help needed
    1994 vr ss 5.0L
    Feb 2011
    perth
    Default Crane Cam help needed
    hi there guys i need some help with a cam that i have bought from a guy for $100 brand new in box.
    the number i have found is 883931 which leads me to believe its a hydraulic cam. the questions are as follows
    1. What are the best lifters to go with the cam?
    2. Do i need to raise the comp?
    3. Whats the best way to raise comp if need be?
    4. What else do i need to do for the cam to work propperly
    i already have the exhaust and i am working on the cai i m fairly fresh when it comes to modifying so any help would be great thanks
    Paul
    VS V6 Acclaim
    Jul 2008
    I would use comp cams 875-12 lifters.
    You can raise the comp with cometic head gaskets or have the heads shaved.
    Get a double row timing chain, stronger pushrods and stronger valve springs.
    You should also get a cam install gasket kit and a vrs gasket kit.
    1994 vr ss 5.0L
    Feb 2011
    perth
    1994 vr ss 5.0L
    Feb 2011
    perth
    VS V6 Acclaim
    Jul 2008
    The 875's are for the v6. I'll look up the 308 part#.
    You would do this easily under a 1k.
    1994 vr ss 5.0L
    Feb 2011
    perth
    ve ssv/vr calais V6 turbo oneday N/A Track car
    May 2010
    Rockhampton QLD
    May 2010
    Rockhampton QLD
    883931 "H268" 206 206 112 448 448 1500–4000RPM HYD
    Its only a very small cam, To go on the cheap i wouldnt worry bout the lifters standard will do
    but 99284-16 Is the anti pump up lifter part number
    comp of the engine will be fine.
    this cam is not much more then standard more of a towing cam.
    1994 vr ss 5.0L
    Feb 2011
    perth
    1994 vr ss 5.0L
    Feb 2011
    perth
    will it still sound better? lumpier or do i need to go a bigger cam for that
    May 2010
    Rockhampton QLD
    Na wont really be any lumper. You want something with about a 110 degrees lobe separation for a bit of lump.
    Pretty popular is the crane 286 cam
    1994 vr ss 5.0L
    Feb 2011
    perth
    May 2010
    Rockhampton QLD
    If you wanted lump and good power gains yeah. But you could still use it and get a bit more power and better performance low to mid range. Or just throw it on ebay and get ya money back.
    heres a link to the crane site scroll down till you find your cam part number and read bout it
    http://cranecams.com.au/pdfs/holdenc...eet_9-9-10.pdf
  1. 284 crane cam?
    By smelty304 in forum V8 Development and Modification
    Last Post: 12-08-2011, 06:21 PM
  2. 304 Crane Cam
    By IRA88 in forum V8 Development and Modification
    Last Post: 25-10-2010, 11:40 PM
  3. new 911 dropped from a crane
    By ausrs in forum The Pub
    Last Post: 10-09-2010, 11:35 AM
  4. [308] crane 288
    By ari666 in forum V8 Development and Modification
    Last Post: 15-07-2010, 08:01 PM
  5. Crane 286 2 big or not???
    By VL2Di4 in forum V8 Development and Modification
    Last Post: 07-05-2006, 12:21 PM
Tags for this Thread
