Results 1 to 2 of 2
Thread: Vs ute water leaking in:
    vs ute
    Mar 2007
    Angry Vs ute water leaking in:
    After leaving my ute stand out in the rain all day, i noticed some water sitting on the passenger side floor mat.After an inspection all drain holes under the bonnet are clear and clean,
    the plastic cowl that runs along under the wipers has a 80mm long crack in it on the passenger side
    where water would normally flow towards the drain.
    Would this be the area where the water would be getting in? if so can these be still purchased from holden or rear spares.
    VS Ute
    Oct 2010
    New South Wales
    Hey buddy,
    i had same problem, all i did was if you look in your tray, towards the cabin the big piece of metal, with screws holding it down, just unscrew it and pull it out. ( also check if all the screws are in every hole water can get through ) you will probably notice alot of water sitting in this area, its not the best fix but i just ripped one of the drainage plugs completely out, and it never leaked.
  1. vrvs sedan water found in boot how i tested to find where the water was leaking from
    By peter1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-01-2011, 08:49 PM
  2. VX leaking water but water tep guage shows normal ???
    By FIN990 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-11-2009, 12:51 PM
  3. Vt Still Leaking Water.
    By Mickonthecoast in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-05-2008, 09:55 PM
  4. water leaking
    By johnny b in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-03-2008, 10:59 AM
  5. Leaking Water?
    By jabbavx in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-03-2006, 07:42 PM
