Hi all
As described I have installed another engine into a statesman. Used same engine harness. Now the engine hunts( revs 2k then down to 500 and so on) the engine codes are air flow sensor and air temp sensor. I have changed these from donor car, I have swapped ECUs. Nothing works. Is there anything else i can try? Both engines were running fine before swap - no idle issues
I have checked all emission wiring and hoses everything is connected.
Doc
wow! no replies with any other ideas.![]()
You said it's giving codes for the air flow & temp sensors? Double check the wiring for those areas, maybe swap it or the sensors with stuff from the old engine.
nathans VY Calais - 'Calais 2.0' | VT Equipe | VS Calais **SOLD!**
I'f there was nothing wrong with the old one why did you change it?
Did you plug everything back in? Brake booster etc?
Originally Posted by Reaper:
Originally Posted by Jecs:
