Hey guys
I got a VS V6 Berlina
The cold air intake box is a normal stock one.
but inside it is a flat filter Im not sure if it's k&n or some cheapy one?
anyway is that better then the round filters?
thanks
Im actually looking for performance not fuel economy
but thanks anyway
id be starting elsewhere if you want performance, what else have you done first?
It's stock 6 apart from 2 and a half inch exhaust
but im looking for better throttle response
so is the flat filter better then the pod?
No. I am actually being serious.
Use a bigger cam.
grab the above with a tune or if dont wanna spend much grab a 69mm Throttle Body and a tune and that will help your throttle response then just cut half the bottom out of the airbox.
Bigger cam
K&n filter with 2 holes on the bottom
stronger valve strings
that should be good for a little better performance?
Yep, you got it.
You might want different length push rods. But I'm not sure.
Don't bother with the K&N just use a $2 ryco.
Half of the air box?
i have just cut like a 30cm circle lol
and THROTTLE BODY 69mm SUIT HOLDEN V6 VS / VT | eBay
is that alright? pretty cheap if it gives you like 10 extra kw
Alright
thanks for the help mate
Step by step so im going to start by cams for now
It wont give you 10kw. Thats a load of BS. I would be supised if you even notice a difference.
30cm circle will be sweet. Just leave it at that.
alright then
just need alot $$ now
Oh, you'll need lifters as well.
When you do a cam do: Cam, Lifters, push rods and valve springs.
just put a V8 motor in it
