Results 1 to 7 of 7
Thread: vs 5 speed revs up when shifting
    vs ss commodore pantha mica
    Jan 2008
    bacchus marsh vic
    Question vs 5 speed revs up when shifting
    hi guys my vs, only cold tho, when i change gears and then clutch to change gears the moter increases revs when i clutch, its not me still having the exelerator egaged abit thinking its either the cable or could it be the throdle body? i can contol it by waiting a second to then change gear. but wont to solve it, cheers daniel
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    cable or sticky throttle body, cleaned out the throttle body lately? Pull the intake hose off and plenum lid off and give good clean with carby cleaner
    Jan 2008
    bacchus marsh vic
    ive only had the car two weeks so dunno?, i was guessing throttle body cause when she warm it seems really good.
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    Jan 2008
    bacchus marsh vic
    VS EXECUTIVE
    Jun 2005
    i have the same problem as well i think it may be a tuning issue if you use an auto computer not to sure though
    Jan 2008
    bacchus marsh vic
    Quick update took the car for the holidays just over 1000km and it did get worse so came home tonight and parked it up and had a good look. It's got factory gas, it's got a gas research system and the throttle cable is connected to this round device and turns on a cog system, I took off throttle cable and knew it was the throttle body cause it was sticking when I played with it, but all I did tonight was grease up the shaft going in and out that attached with the cog, and it's good as new, dunno tried to explain it the best I could maybe a photo tomorrow would suit.
  1. Like shifting gears? Have a look here...
    By VT-565 in forum Parts And Other Items For Sale
    Last Post: 26-02-2009, 09:09 PM
  2. VP 5 speed revs with foot on clutch
    By L67 Calais in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-09-2008, 09:34 PM
  3. auto shifting
    By bigbos in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-12-2005, 07:59 PM
  4. VS Calais revs drop at idling speed
    By vsuterus in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-12-2005, 01:22 PM
  5. revs to high and gears not shifting right
    By timboss04 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-11-2005, 04:35 PM
