Results 1 to 4 of 4
Thread: Vehicle doesn't run on gas after backfire
    96 S II VS Clubby, 96 VS S II Executive
    Jul 2010
    perth wa
    Default Vehicle doesn't run on gas after backfire
    My mates got an imco gas system on his car and after experiencing a backfire (i suspect through the induction system), the vehicle will refuse to run on gas now but is completely healthy on petrol. He has had leads, spark plugs, air filter, resetted the gas system by a mechanic to no avail. If anyone has had simlar experiences, any info whatsoever would be greatly appreciated.
    cheers guys
    Stuntmanmike: At least he didn't advise for me to check the head light fluid and bring it in to tune the radio...
    Jonno's Avatar
    Jonno is offline :)
    Nov 2010
    Vic,
    duel fuel alwase end up having proboblems, car needs to be tuend to run one and one only otherwise itll eventually say its had enough
    Quote Originally Posted by Rufys View Post
    yup! I think I might actually be gay
    Patti2912's Avatar
    Patti2912 is offline P4TT1
    93 VR S Commodore
    Jul 2010
    St. Kilda
    I had this problem a while back mate, take it to a gas mechanic and they will be able to fix it up, i can almost guarantee you that the backfire blew the head off your gas mixer, this happened to me twice in 2 weeks when i had the problem. The back fires are almost always caused by old plugs and leads, so get them replaced while your there and you shouldn't have a problem with it back firing anymore. Get them to replace the mixer (cost me $40.00 about a year ago) and that should fix the problem. Its a pretty common thing with un serviced or poorly serviced duel fuel systems. Also check your air box as you may have cracked that as well.
    As said above, duel fuel systems do commonly have problems, unless you get it serviced regularly.
    I get my car serviced between every 5000 to 10,000 k's by my mechanic, and take it to a good gas mechanic that i know around the same time and i haven't had any issues in a very long time.
    Hope this helps mate.
    Edit: i apologize for not reading your post in full and mentioning leads and plugs :P
    But still, head off the gas mixer
    Quote Originally Posted by Morton View Post
    You're better off using a 175g can of Masterfoods Wholegrain Mustard. I just measured that, and it's 9.5cm tall. Keep one in your car at all times, and if a police officer tries the "coke can test", you can tell him what I told you
    Jul 2010
    perth wa
    cheers patti mate thats great info, i'll remember that and i'll pass it on
  1. LPG Backfire protection?
    By gontix in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-09-2010, 01:47 AM
  2. backfire mith
    By too in forum The Pub
    Last Post: 20-07-2010, 07:26 PM
  3. Backfire help?
    By pauagirl in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-01-2009, 08:54 PM
  4. Backfire
    By vsstock in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-07-2008, 05:21 PM
  5. gas backfire
    By johnvtls1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-11-2007, 12:07 PM
