Gday guys and gals i have a problem with the tranny on a vs series 2 wagon. it was leaking like crazy so i replaced the gasket and it still leaks. its comming from a cover plate just front of the tranny is there anything up there that could pour the fluid out
Front main seal of the transmission. Stall convertor Seal, Rear main seal of engine are all in that area.
check the trans cooler lines also. Mine must have a break at some time and they have a hose into part of the line. Mine had a pinhole in the hose. I was 2 mins from pulling the trans out.
