Results 1 to 5 of 5
Thread: Needs work
    HSV VT MANTA
    Jan 2010
    Default Needs work
    Hey guys, after picking up my vs, i've recently discovered that i need a new left hand engine mount. Left hand being passenger side. And i think it may need a new tranny m ount. I haven't been underneath it to check tho.
    Are they hard to do? i know i need to move the ac compressor etc but yeah.
    Anyways, my gearbox is heaps clunky and takes forever to kick down. I was thinking of getting a shift kit but as my commo has 180k+ i think a rebuild may be in order. Anyone know of any shops that will rebuild my auto and put a shift kit etc into it?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Engine mounts are not the easiest to do and the LH is the worst - do a search on this forum as it has been covered many times. Any auto trans shop will fit the kit you want and overhaul the box...at a price...expect a minimum of $2000. At 180k the box is due to fail so it might be a good time to consider all options....like a manual conversion!
    HSV VT MANTA
    Jan 2010
    she's got 180 thou on her. I'm looking for a manual conversion but they're not cheap.
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    Quote Originally Posted by Mr.38L View Post
    depends on what you want to spend.....you could just get a 2nd hand auto from the wreckers and get your local mech to pop it in for you....best of luck either way
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
    95 VR V6 Turbo Ute
    Oct 2009
    Sydney, North Shore
    New engine mount will be from memory around 150 for genuine gmh, and about 60 maybe for one that is the exact same, that repco sell, (which I have bought, which are fine) which you can also source through holden spare parts. And as Hako said, yes the left hand side is an absolute prick to get to. I remember when I put my new motor in and was putting the lhs one on, I was thinking to myself, imagine trying to change this mount in place...
    What makes you think it is an engine mount anyways?
  1. Speedo/alert won't work - replaced cluster, still won't work
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-05-2011, 10:33 AM
  2. VR 1994 Indicator doesnt work (Hazard lights work)
    By rester in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-09-2010, 01:40 PM
  3. Speedo/alert won't work - replaced cluster, still won't work
    By VS Omega in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-02-2009, 06:54 PM
  4. SWAP: My work for your work!
    By thisispete in forum Swap / Wanted to Buy / Trade
    Last Post: 20-11-2005, 06:55 PM
