Results 1 to 10 of 10
Thread: Is it the auto or diff?
    VE SIDI
    Apr 2011
    maryborough vic
    Default Is it the auto or diff?
    All,
    Need help ---sons VS won't move in reverse not even roll in neutral. Jacked it up and same. Is it the diff or auto?:
    VT Calais
    Aug 2010
    VE SIDI
    Apr 2011
    maryborough vic
    VT Calais
    Aug 2010
    VE SIDI
    Apr 2011
    maryborough vic
    Quote Originally Posted by DavesCalais View Post
    Does it move in any of the gears?
    Drive is okay, just no reverse or wheels dont move when on jack
    Jonno's Avatar
    Jonno is offline :)
    Nov 2010
    Vic,
    Check trans fluid then take it to a automatic trans place
    Quote Originally Posted by Rufys View Post
    yup! I think I might actually be gay
    vs executive s1/ vz berlina
    Mar 2008
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    If the wheels dont move maybe the linkage is out of adjustment and not coming out of park fully.
    Cracka is offline Banned :P
    Old Sneakers
    Mar 2011
    Croydon
    Although I tend to agree that the issue is within the transmission I simple test you could do is grab your spanners, jump under the car and at the diff, using ONE spanner only (As the nuts will self locate) undo the bolts securing the tailshaft to the diff.
    You will need the rear end raised off of the ground and you will need to turn the tailshaft to do this (Luckily you seem to be able to move it one way at least) I would suggest leaving it in gear and undoing what you can, then putting it in neutral and turning the shaft and putting it back in gear and removing the rest.
    Remember to chock the front wheels too :P At least once the two components are seperated you can tell 100% which one is at fault.
    1997 VS COMMODORE,1996 GTS-R COMMODORE
    Feb 2011
    NEWCASTLE
    It could be the clutch pack if so then your looking at least $1100
  1. vt auto v8 diff wanted
    By LESK1946 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 21-07-2010, 08:01 AM
  2. What diff oil do i use on VX V6 Auto with IRS?
    By Fuzzypumper in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-05-2009, 07:21 PM
  3. diff gears 3.45 auto vs
    By clyde in forum V6 Development And Modification
    Last Post: 10-01-2008, 12:58 PM
  4. vn auto diff in manual...
    By sp4nky in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-10-2007, 09:29 PM
