hey everyone, just put 20'' sigs on my ute and i lowered the rear with ssl king springs, and its slighty tucking the tyre, ive seen some other vs wagons and sedans and there tucking alot more than mine, and my ute is just about siting on the bumpstop mounts, about 10mm off.
just wanting to know if theres anyway it could go lower, thanks.
Some say cut the bump stops n some say buy smaller bump stops, but I'd say air bag the rear end n it will tuck how ever much u want
1993 VR CALAIS 5 SPEED MANUAL,Lowered all around on pedders, 20 inch G8s, Option audio front splits, option audio amps, sound stream subs, pace maker extractors, high flow cat, 2.5inch lukey cat back exhaust
airbag it or get some sssl springs but you will defiantly need shortened bump stops and you wont be able to carry a lot of weight
at the moment it has no bumstops at all, haha pretty rough ride
u'll find that most vr/vs sedans that r REALLY slammed r using barina, camira, daewoo, torana or bmw springs.. for irs that is
where did u buy the 20" sigs from?? been tryna track down a set but can only find 2nd hand..
one of my mates in melb, ill ask him what joint next time i see him
Get some rear sedan SSSL springs (sedan springs are lower than ute ones), you wont be able to have bump stops because it will be metal on metal. I had that on my ute for about 6 months, was soo low, by far one of the lowest around, but the ride is absolutely terrible. So I guess you have to ask yourself, height for comfort....
