Results 1 to 7 of 7
Thread: Dash Lights Dead
    VS Commodore Series 1
    Jan 2008
    Default Dash Lights Dead
    Hey All,
    The dash lights in my VS have died. Is it common that all dash lights die at once or is there something more going on that I should look into?
    Cheers.
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    fuse is the first thing to look at.
    and 3 Dangerous non ABS VN's
    VLC86's Avatar
    VLC86 is offline ..stay N/A..
    VL Calais
    Dec 2009
    unlikely that all have died at once. more likely that there's some sort of issue with power getting to the dash. as said, check fuse first then might need to check by putting a good globe in the back to see if it works
    World's slowest project
    Quote Originally Posted by hi_ryder View Post
    for entertainment purposes only, hi_ryder does not condone the murdering citizens on assumption of theft, or illegal firearms possession
    VR SS
    Sep 2010
    This happened to my VR the dash lights went out, turned out to be a short in the wiring between the dash and rear lights
    Also check the tail lights still work as they are on the same fuse
    shanhsv's Avatar
    shanhsv is offline Luvo
    VS Berlina V8 5speed
    May 2005
    Muswellbrook,NSW
    Check that the dash loom is plugged in right
    WTB:VR/S HSV 250km/h speedo cluster
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    Quote Originally Posted by poxpox View Post
    Hey All,
    Cheers.
    thay all wouldnt blow at the same time......start with checking fuses,,,,cheers
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
    VR SS Commodore
    Nov 2006
    When you find out what was wrong can you let us know please. My VS SS has the same problem. Thanks
  1. Car completely dead even with Jumper leads (No ignition lights)
    By BrisbaneVTOwner in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-01-2011, 04:28 PM
  2. VY Insturment Lights are Dead
    By Secki in forum VY Holden Commodore (2002 - 2004)
    Last Post: 15-12-2007, 10:13 PM
  3. No interior lights, dash lights or elec windows vk
    By ported in forum Electrical Wiring / Questions
    Last Post: 18-09-2006, 05:10 AM
  4. died at the lights, no power (electrically dead)
    By ucwepn in forum VL Holden Commodore (1986 - 1988)
    Last Post: 05-07-2006, 10:45 PM
  5. No Parkers, Speed Alert, dash lights or shifter lights.. Help..??
    By Grommitt in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-04-2006, 10:36 AM
