Results 1 to 16 of 16
Thread: v8 oil leak
    01 VU SS UTE
    May 2005
    Moree
    Default v8 oil leak
    hey all my 5l v8 has developed an oil leak on the drivers side it drips a few drops on to the ground so it seems to me as if its pretty bad. it looks like its coming from the top of the motor somewhere as theres a bit of oil on top of the gearbox and running down and burning on the y-branch. ive checked the bak of the rocker cover and it seems to be dry so where else could it be coming from up top thanx heaps for any help
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    My first geuss would have been rocker cover should replace those gasket anyway they're cheap as chips. Next probably inlet manifold gasket
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    VB SL/E
    Dec 2008
    Double check it is not dirty power steering oil, the low pressure hose suffers heat damage and slowly fails over time.
    vs ute
    Mar 2007
    The two main areas that Ive come across,is the front right hand corner of the intake manifold (or the back in your case) and the rocker cover gaskets.
    Sumps can weep a bit to, but there generally ok.
    01 VU SS UTE
    May 2005
    Moree
    checked the rocker cover gaskets and they seem dry at the back so im stumped lol
    VS Senator
    Oct 2009
    There is an o ring under the dizzy. If that breaks or perishes it also will leak oil down the back of the motor.
    01 VU SS UTE
    May 2005
    Moree
    im hoping its not that then its only on drivers side as far as i can tell
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    dissy is on drviers side....
    If it hasnt been removed recently dissy can be so coked in there they can be a real mission to get out
    01 VU SS UTE
    May 2005
    Moree
    VE series2 E3 HSV Clubby & VS Calais 5.0L
    Mar 2010
    Around WA
    i suggest you use an inspection mirror & a light to see if it is the gasket for the inlet manifold valley or the distributor.
    My valley gasket blew out & I've got to replace mine, & a sump gasket to boot.
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Can also be caused by the rear main seal leaking. You really need to get your car up on ramps (or stands). Clean everything off with spray can degreaser followed by water. Drive it around for 10 kms or so and then put it back on ramps (or stands) and see where the leaks are coming from. 5l oil leaks are very frustrating !!!
    01 VU SS UTE
    May 2005
    Moree
    thanx for all the help turns out the valley cover gasket is leaking at the bak near dizzy and running down. any tips or how tos on replacement? thanks
    VB SL/E
    Dec 2008
    vs caprice
    Dec 2010
    brisbane
    pull the manifold off bud with all the 14mm or 9/16 bolts buy the manifold gaskets and clean up ur gasket surface use a bit of gasket glue to hold em on bud some valey cover gaskets come with a double sided tape to help keep them in position i would drop ur water though cause when u take the manifold off it be full of water
  15. #15
    01 VU SS UTE
    May 2005
    Moree
  16. #16
    vs caprice
    Dec 2010
    brisbane
    lol i built my motor so i would attempt it me self if ur handy with doing small jobs with ur tools then i would atempt it ur self bud just try not to knock the dizzy to much it will slide away from it even though it may be tight u only need to move it 1 degrees and that can effect ur timing alot
  1. [LS1] Ls1 Oil leak
    By GraceSpaceAndPace in forum LSx Development and Modification
    Last Post: 01-10-2010, 11:49 AM
  2. Bad Oil Leak, Need Help
    By Keesh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-08-2009, 10:20 PM
  3. oil leak
    By Black.Label in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-03-2008, 10:16 PM
  4. VS V6 oil leak
    By mcvk in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-12-2007, 03:34 PM
  5. oil leak in 1 day old vt
    By rekless driver in forum General
    Last Post: 09-12-2006, 09:13 PM
