Help ! so I've had the airbag light come on. Comes up fault code 5 - passenger airbag squib circuit malfunction. problem is,I don't have a passenger airbag. I've had the codes cleared by a mechanic twice. Each time the light comes back on after about a week or so. Any ideas !!
If its saying theres a fault with the passenger side airbag when you dont have one,then Id say its a faulty SRS module, this module is located under the drivers seat mounted to the floor.Heres a list of the VR/VS SRS error codes..I dont know where the guy who did the diagnostics came up with code 5 from...
DTC CODE DESCRIPTION
13 Driver's Airbag Circuit Short to Earth
15 Driver's Airbag Circuit Short to Battery
23 Passenger's Airbag Circuit Short to Earth
25 Passenger's Airbag Circuit Short to Battery
31 Driver's Airbag Loop Resistance High
32 Driver's Airbag Loop Resistance Low
33 Passenger's Airbag Loop Resistance High
34 Passenger's Airbag Loop Resistance Low
43 SRS Warning Lamp Short to Battery
44 SRS Warning Lamp Circuit Fault
48 Ignition Input Voltage Low
49 Ignition Input Voltage High
53 Configuration Mis-Match
55 Sensing Diagnostic Module Fault
66 Airbag Deployment Commanded
