as title said i want to know if some VZ SV8 FE2 rear springs will fit in a VS Berlina V6 with IRS
will fit... but probably wont lower your car at all if thats what you're hoping for?
can you explain why they wont lower pls![]()
hahaha vz chchick77 your everywhere these were your springs im loking at but wanted to check first
because VZ v8 springs arent meant for a VS v6, yeh theyll fit but because a vz is heavier the springs would probably have a different load rating to vs springs
seeing as fe2 only lowers a vz slightly i doubt its going to lower a vs much or at all...
if you dont want the springs.. send me a PM, been looking for some.
FE2 are better handling thats why all the cop cars have them
FE2 is rubbish.
Its *Slightly* lower then standard, an inch at most. In a VS, they will sit about stock height.
I've got a set of VY FE2 springs in the shed if someone wants to buy me a slab for them...
You do realise they won't lower very far yeah?
They've done 122,478km's.
PM me when you're ready.
i took mine out at 20,000kms and are available still they are off a VZ SV8 which is also up for saleLol yeh I am every where
