Results 1 to 9 of 9
Thread: genuine crank seal
    none
    Apr 2011
    perth
    Exclamation genuine crank seal
    Hey guys just wondering how much will this be and is it a big job?? its for a vs ss
    VE SSV Sportswagon, VK race car, Kwaka ZX12R!
    Oct 2003
    Bayside Melbourne
    .......front or rear??
    Smitty...with the VE SSv SII Sportswagon, VK race car and... Kwaka ZX12R
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Presume you mean the rear main seal? If so it's a big job that needs to have the engine removed to do it properly. Also, I believe there is an issue with the quality of the seals that are around at the present time.
    VS Executive S2
    Aug 2010
    melb
    Could you please elaborate?
    I just had an engine changeover done and replaced the rear main seal at the same time.
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    There's no "issue" with quality per se. Its a shitty seal made of ROPE. Its just poor design by holden and all leak eventually. If you're referring to failing early, then it hasnt been installed properly. Probably someone trying to install it on the dodgy without taking the motor out and they havent seated it properly.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    VS II V6 Commodore Ute
    Jan 2011
    Campbelltown NSW
    Quote Originally Posted by Vee-ard View Post
    i dunno about the vr one
    but vs isnt rope its a rubber/pastic seal
    there someing like 15-20 bucks from holden
    u can drop the gear box out and do it that way to make it easier if you dont have an engine crane ect
    gotta change mine cause its pissin out oil
    EDIT: miss-read haha im talking about a v6
    Mar 2008
    Aug 2004
    Mar 2008
    Quote Originally Posted by BlackVXGTS View Post
    Vs ss = v8.
    oops i need to read posts better
  1. Door Seal or Window Seal
    By crackah in forum VE Holden Commodore (2006 - ?)
    Last Post: 25-10-2010, 09:57 PM
  2. changing crank seal
    By vrcalais5ltr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-11-2009, 07:41 AM
  3. How to change the front crank seal in vp v6
    By Abrowne70 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-03-2009, 08:54 AM
  4. Should I replace the front crank seal?
    By Wagon_Wheel in forum General
    Last Post: 21-12-2008, 01:16 PM
