Hi guys, i just want to know if the VR method of wiring up the speed sensor for an auto to manual conversion can be used on VS V6 ecotec if so where do you need to splice into the signal wire from the computer. Is it behind the dash cluster or right at the computer. Thanks
Im pretty sure the wiring for the gearbox is the same for both vr and vs so it should be fine. And you could hook up the speedo both ways just depends on how you wanna do it
ok ill give it a shot last time i tried it spliced right at the ecu and the car just stalled
Make sure you join the right ones. I think there are two that look the same at the ecu. And if you cut the wrong one the car wont drive properly.
thanks see how i go tomorrow
